Question about Gaggia Titanium Espresso Machine
How to remove dispersion screen on a futurmat rimini compact espresso machine
How do i fix the Coffee flow from only dripping through?
if it has a filter ,replace. use vinegar through the water resevoir. fill it and turn it on.
May 26, 2014 | Rancilio Silvia Espresso Machine
My Gaggia syncrony digital has just stopped working....the coffeee is still being ground but there is no coffeee coming out....no water seems to be getting through. Any ideas?
There is one of 2 things going on either the machine needs to be descaled and or the brew unit screen is blocked. Remove the brew unit from machine and check screen below the red o-ring.
Aug 04, 2011 | Gaggia Syncrony Compact Coffee...
Hello. No water comes from coffee dosing, the led is blinking (san marino ckxe coffeeemachine), but the pump is working
Remove the shower screen and try again if that does work then the machine is blocked at the top of the group (Big nut on top front) in the metering jet.
Apr 26, 2011 | Astoria Compact CKXE Espresso Machine
The steam works fine on my X5, but no water comes out of the coffee part. The pump sounds like it's working.
Check the shower screen and the dispersion block for clogs, they need to be cleaned periodically.
You can remove it by unscrewing a screw in the center of the shower screen.
Mar 04, 2011 | FrancisFrancis! X5 Espresso Machine
I have a gaggia syncrony compact. Everything works well, except the coffee doesn't come out the proper outlet. Intead, the grinds and all the liquid goes into the waste compartment.
Your thumbscrew is stripped. If you remove the brew unit and push down on the thumbscrew your filter screen should have a gap in it. You need a new thumbscrew. Don't use the key to tighten it. That is why they call it a thumbscrew. Finger tight.
Sep 11, 2010 | Gaggia Syncrony Compact Coffee...
I have a Gaggia Evolution expresso maker about 8 years old. When button is pressed to start motor it just hums and no hot water comes out. The motor only runs if I open the steam outlet
Try this, under the grouphead, there is a screw and screen, remove those, and check screen to see if it is clogged, when screen is removed press button to brew, if water flows freely then problem is at the screen, if no water flows, then it is on the inside of the machine. You will have to run a descale cycle to clear out machine. Check the folling pic for the screen location.2722dbe.jpg
Jun 27, 2009 | Gaggia Syncrony Compact Coffee...
GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
Small Particles Sand & White color particles from dispersion screen group head & in water
I had this happen about 6 months ago. It was the heating element. I had to have it replace - about $225. Ugh. But it works great now. Good luck. If you have an espresso repair shop you can take it to, they can hook it up to an electrical tester and let you know if it the element.
Jun 08, 2008 | Rancilio Silvia Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
27 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
