Question about Sony XAV62BT Car Video Player
Sony xav62bt will not play cds or any media
I put a cd in and it says its playing but no sound comes out, same with the usb and other media
dobhan
  • 105 Answers
SOURCE: CD plays CD's intermittently does not recognise some CDs
in my side i already encountered that problem.this is what eve done,i'm just clean the lens with cotton and one drop of alcohol, after cleaning,its work.....just follow what i'm doing....
Posted on Jan 25, 2008
  • 133 Answers
SOURCE: My sony MHC-GX99 stereo will not play my cds.
Some possible causes:
a) dusty laser lens - cleaning it is the solution, you may use the lens cleaner disc (the one that uses liquid), this can be purchased in many shops. I prefer to clean the lens manually, using a cotton stick and some ethyl or isopropyl alcohol (DO NOT use acetone, benzene or similar strong solvents, these will ruin the lens).
b) dirty brush contacts inside the spindle motor (i repaired quite some CD players that had this kind of trouble). They cause the motor to spin with less power so the driver tries to compensate putting more power into the motor, which causes a feedback effect on focus (it may not work properly). The best solution for this is to replace the spindle motor (if you can find one), the second best solution is to clean the brushes and the commutator (that's what i usually do), but this is a pretty delicate and somewhat complicated procedure since you have to open up the motor, clean it and then put it back together in a correct way. I wouldn't recommend doing this unless there is absolutely no way to obtain a new motor (if you are truly interested in learning how to do it, post me a message, i'll explain it).
c) the main power switch has oxydized contacts, which means that the voltage on the primary of the power transformer is a bit lower, and, consequentially, all of the secondary voltages are lower, too. I know it may sound weird, but i had some players in which i cleaned the lens (on BOTH sides plus the mirror inside the laser), opened and cleaned all of the motors, but they would still not work correctly. Only after i've cleaned the contacts on the main power switch did they return to normal functioning. Obviously it's much easier to change the switch to solve this (if you have a spare one). You can check if the switch is the cause if you bypass it (you need to bring the mains voltage directly to the primary of the power transformer, but do it with caution as mains voltage can be LETHAL to you and your CD player - i don't recommend this either if you're not trained in electric safety).
These are just some of the possible causes. It may as well be that the real cause is something else, so don't take any of these for granted, they are just suggestions.
Anyway, i hope you can fix it (or at least have someone do it for you).
Good luck and best regards
3rq8 (triarcuate)
Posted on Jul 18, 2009
welcomejee
  • 10594 Answers
SOURCE: SONY DVD-CX995V "cannot play"
In that symptoms optical block (lens) sounds defective and requires replacement.
Let me know if you want to replace optical block by yourself to provide you more technical info.
Posted on Aug 14, 2009
collegetutor
  • 125 Answers
SOURCE: sony Q58A will play DVD but not audio cd or data cd. Help!!!!!!!
Are you sure that you have the file type associated in your Windows operating system to a Music player like Windows Media or iTunes? This may be the most common reason that music CDs won't play.
Posted on Sep 16, 2009
SOURCE: I have a sony walkman
All of a sudden my player says I have no songs available for playback and yet it is full. What do I do?
Posted on Nov 08, 2009
My sony mp3 dont stop to show me no data when i want to listen music
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Feb 25, 2013 | Audio Players & Recorders
How to put audio books on my sony nwz-s544
MP3 players can only play music files and audio books in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player using the USB cable.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_filesb>
May 29, 2012 | Sony NWZ-S544 Digital Media Player
Digital music player nw-e013f sony, no audio songs play,
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
Mar 19, 2012 | Sony NW-E003F MP3 Player
When i plug my usb into my sony nwz-a816 media player it just charages and i cant put music on to it
Feb 26, 2012 | Sony NWZ-A816 Digital Media Player
I have a Sony Vaio desktop with XP. My DVD-CD
Have you tried burning a CD in the new drive? Because the drive is a DVD it will always be recognised as a DVD, but should work perfectly well with CDs both playing and recording.
Nov 07, 2009 | Sony VAIO Digital Studio PCV-RS220 PC...
Sony Q58A will play DVD but not audio cd or data cd. Help!!!!!!!
Sep 16, 2009 | Sony DWQ 58A 8x8x4 Slim DVD RW w/ NTI DVD...
How do u hook up a USB cord into the radio and my burned cd wont play is there a way to make it work?
well you can really just hook a USB cord into any cd player it has to come with one built into it already and if its not playing your burned cds then its probly of low quality or old. or it doesnt recognize the format that you are burning the cds with especially if your using windows media player to durn the cds some cd players dont read WMA files (windows media assotiated) files
May 06, 2009 | Kenwood KDC-X890 CD Player
I have an Sony RX66 the cd changer will not pop to play on.
My sony stereo rx66 after finish to play the first cd stand of going to play the second one, it put the cds one of the top of the other or under the tray. Can somebody help me?
May 04, 2009 | Sony MHC-RX66 Shelf System
I cant play cds on my wharfedale pcd 6200 usb
I think you need to press and hold the Play button (marked PLAY/PAUSE) to switch between CD playback and the USB port (you can store mp3 files on a USB stick and play them directly) on the front of the device.
Try inserting a disc, switching the unit to CD mode, press and hold Play until the display changes and the CD spins up...
Might just work?!
Duncan
Mar 22, 2009 | Audio Players & Recorders
Sony cdx-4000x
if you are playing original cds with no scratches try a cd lens cleaning disc if that fails it sounds like the laser
May 21, 2008 | Car Audio & Video
Sony XAV62BT Car Video Player Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
