Question about Aiwa PX-E860 Turntable
Aiwa px-e850 rotation
I have a aiwa px-e850, its fully functional , but the speed seems to be a little fast, even in the slowest speed, wich is 33. how do i adjust its speed so it doesnt change the musics playing!?
5 Suggested Answers
lesliemurphy
  • 69 Answers
SOURCE: A needle for AIWA PX-E860?
try this company?
mailto:info@needledoctor.com
Posted on Oct 07, 2009
  • 396 Answers
SOURCE: how do I attach the turntable belt to the Aiwa px e850
Lift the platter off the turntable. You can identify the motor spindle by using your fingers to turn the round shaft which rotates freely. Remove the rubber mat off the platter. Place the belt around the outside of the drum on the bottom of the platter. From the top of the platter, place your finger in one of the platter holes and tension the belt so it will not fall off or twist. Griping the platter trough the holes while keeping tension on the belt place the platter on the turntable aligning your finger with the belt to the motor spindle. Place the section of the belt on your finger over the motor spindle. Replace the rubber mat on the platter.
Posted on Jul 21, 2010
STYLUSCITY
  • 271 Answers
SOURCE: how do i remove the
Hi, grip it at the front edge and pull downward then forward. styluscity@gmail.com
Posted on Sep 13, 2010
STYLUSCITY
  • 271 Answers
SOURCE: I have the Aiwa model
Hi, no. Cheers John. Styluscity@gmail.com
Posted on Oct 03, 2011
Testimonial: "Yes this turntable does indeed have a preamp..Just take the mat off the turntable and looking through the access hole turn the turntable around to the preamp on/off switch..Connecting this turntable to a phono plug the switch will need to be in the off position or if you connect this turntable into the line in jacks, the preamp switch will need to be switched to the on position.. "
If I put a external preamp on a aiwa px-e850, bypassing the built in preamp, will it upgrade the sound?
Hi, I doubt if you would notice any improved sound, the speakers (in my opinion) make the most difference.
Jul 08, 2016 | Aiwa Audio Players & Recorders
How do I remove the stylus of an Aiwa PX-E850 Turntable?
Hi, grip the stylus between thumb and forefinger. Then in a pulling down and forward motion remove stylus. Cheers john. Stylus City
Apr 02, 2014 | Aiwa PX-E860 Turntable
Speed seems a little slow on 33s. How can I fix this?
If the problem is encountered on both speeds, 45 & 33, then there is a high chance that you are in need of a belt replacement.
Here is a general guide on how to replace a turntable belt.
You can also use it to check the belt status.
Jul 23, 2013 | Aiwa PX-E860 Turntable
Aiwa PX-E850
Hi, most likely the auto function needs resetting. With the power off turn the platter manually clockwise a dozen or so times. Power up and play. Cheers john.
Apr 08, 2013 | Audio Players & Recorders
AFTER adjusting the speed setting to 33, all the records are playing too fast, they sound like chipmunks. I tried all three settings and while each speed is different from each other they all seem to be...
If it says your speed setting in on 33, than you have a problem with the speed control inside of the turntable, there is not much you can do in that area. 33 is the slowest speed too, so it seems like it is stuck on 45 or 78. Call Teac if you are still under warranty.
May 15, 2011 | Teac SL-A100 Turntable
Playback on the turntable is sped up
The first step to resolving this issue is to select the appropriate RPM speed for the record that you have in hand. If it is not a simple 33 1/3 RPM record set on 45 RPM, then it would seem that the phono motor speed could require adjustment. Your phonograph is a belt-driven PX-E860 K with a DC servo motor.
Some people mistake the the 7"/LP record size LEVER for the rotational speed BUTTON (33 RPM when raised; 45 RPM when down).
In the case of needing to actually callibrate the rotational speed, underneath the unit there is a hole labeled "33" & a hole labeled "45." Using a very fine precision screwdriver, you can callibrate the speed of each. Insert the screwdriver into the repsective hole past the rubber & slightly turn the screw (rotational speed increases as you turn the screw clockwise).
Jan 07, 2011 | Aiwa Z-L500 Shelf System
How do i remove the stylus from aiwa px/e850
Sep 09, 2010 | Aiwa PX-E860 Turntable
How do I attach the turntable belt to the Aiwa px e850
Nov 05, 2009 | Aiwa PX-E860 Turntable
I need a spare turntable belt for a Aiwa PX-E850 turntable. What size is needed?
I did it by searching the internet rather than being led into a a system which costs money.
JMB
Aug 02, 2008 | Aiwa Audio Players & Recorders
Aiwa PX-E860 Turntable Logo
207 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
