Question about Bissell 1631 PowerSteamer ProHeat Canister Vacuum
How do you hook it up? - Bissell 1631 PowerSteamer ProHeat Canister Vacuum
How do I replace Riccar 8625 upper cord hook?
There are various small parts that make up the hook. First insert the L bolt through hole in handle. Put cord holder on L bolt, put lock washer and nut on and tighten nut. Then put cord hook on L bolt followed by spring, large washer, lock nut and another nut. Snug nut up and test to be sure it will swivel.
Feb 19, 2015 | Riccar Vacuums
How do you hook up to the faust
This is an old machine. It comes with all the adaptors to hook the 1/4" water line to the faucet. You need to remove the arator from the faucet to hook it up and use the adaptors to match your faucet.
May 17, 2014 | Bissell 1631 PowerSteamer ProHeat Canister...
How to replace power cord hook
The lower cord hook is held in by a screw removed with a phillips screwdriver. The upper cord hook has a nut on an "L" shaped bolt. The "L" goes through the hole in the handle. Reassemble the cord hook parts in the same way they were before.
Feb 12, 2014 | Riccar 8955 Upright Vacuum
Blockage in dc23 hose
Well you can do it the costly way or you can do it the not so costly way.A.take it to the company you bought it from or,B. open a clothes hanger, straighten it all the way out, remove the bigger hook,by bending back and forth till it comes off,discard it. Now take one end an make a small hook, drive it up into the hose and try to hook the bags end with the hook on the hanger..Remember the hook has to be bent in a hook shape for this to work. Please unplug your vaccum.
Nov 26, 2013 | Dyson DC23 Bagless Canister Cyclonic...
I have a nv30 infinity vacuum. The handle is clogged with a sock right where the flexible hose begins. I cannot reach the sock even after removing the telescoping tube. How can I unclog the handle?
Hi Jackie ma268...
You need a metal coat hanger nd a pair of pliers.
You will straighten out the coat hanger with a pair of pliers, except the end that you hang the clothes hanger up with, because it has got the hook already made..
After you have gotten the hanger straight, you will take the hook of the hanger and make a smaller hook that will slide easy into your hose with the hook being able to catch the sock ...once it has caught the sock, then twist it a few times so that it will get caught up in the sock really well...then pull the sock out of the hose...Job done.
Please take time to rate me
Sep 06, 2011 | Vacuums
The system was removed to another location and one
Yes it could. It sounds like your low voltage wires are not hooked up properly. You need to get your contractor back out there.
Joe
Sep 30, 2009 | Broan-NuTone CV353 Central Vacuum
Cord hook broken
You may call Hoover Service @ 440-996-2000
Sep 30, 2009 | Hoover U6616-900 WindTunnel Bagless...
How do I hook up an aqua chem pool vacuum for an above ground pool?
i need to know the same thing,I hooked everything up as it looked right but no suction?I hooked the 1-1/4 hose to the vinyl liner vac. head then hooked the other end to my intake hole wich sucks into my filter,but i notice the filter water is not circulating properly,the filter itself is drained of water? will this burn it out or what?
Jul 18, 2009 | Vacuums
Belt
make sure the belt is in the middle before u put the head onto the vax front. turn the nozzle to red to hook the belt on . should be easy if the belt is int he middle space and up not down.. the the hook should hook onto the belt quite easily.. put the head onto the vax front and turn to green for go. the green light should be on if u put the belt on correctly .
Sep 01, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Rainbow aqua mate II instructions
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
Jan 27, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Bissell 1631 PowerSteamer ProHeat Canister Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
