Question about Refrigerators
Wiring diagram themostat idesit fridge - Refrigerators
3 Suggested Answers
SOURCE: need wiring diagram for transformer and themostat
http://www.nordyne.com/Literature/7083400.pdf
There is a manual it has a diagram inside. http://www.nordyne.com/Literature/708340b.pdf
That's all the info i could find mentioned at all on the net, I did exhaustive searching....
Posted on May 15, 2010
hvac1960
  • 2133 Answers
SOURCE: I want a wiring diagram for an external themostat
Please try with following site:
SERVICEMANUALS @ COST www.mauritron.com
Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Posted on Dec 17, 2010
Idesit built in fridge, compressor running, fridge doesn't seem to be cold although there is a build up of ice on back wall, happened a couple of times , if i defrost works fine for a while then back...
simple thing first make sure the door is sealing properly, unlikely to be this.
push the back wall of fridge with your hand, it should be solid.
if it is spongey it means the insulation has broken down and you need a new fridge
if not the back wall more than likely a blockage in the system, you will need a pot man out to check the system.
if this is the case and your fridge is over 5 years old dont waste money on repairing, buy a new fridge. if under 5 years def contact indesit company
Jun 19, 2011 | Refrigerators
I want a wiring diagram for an external themostat and a complete wiring diagram mine is missing
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Dec 17, 2010 | Amana PTH123B25AJ Heat Pump Air...
Need wiring diagram for transformer and themostat
May 15, 2010 | Intertherm P3RC-030K Air Conditioner
Fridge is freezing food
ajust your themostat down and if that dont fix it ,you will need to replace the themostat part # 2198202
contact searsparts.com to order it
Feb 01, 2010 | Whirlpool ED2FHGX Side by Side...
Idesit BAAN134 PSUK fridge keeps freezing food . The fridge part of my tower f/f keeps freezing food even though I have turned the dial down to the minimum the temperature regularly drops to below...
If it is an electronic thermostat it could be that the engineer has changed the board but not the sensor which reads the temp. If it is a mechanical thermostat it may be hes fitted the wrong type.It could also be that the system is short of refrigerant and the actual refrigerant charge is not getting all the way to the thermoststs sensor to switch it off, the back wall of the fridge should be frosted at least 3/4 of the way down and not just forming in a small part of the fridge.
Jan 05, 2010 | Refrigerators
I am trying to replace the thermostat in my Westinghouse fridge. How do I remove the square plate which provides the cooling? The plate is secured to the backwall of the fridge by 4 plastic anchors/screws...
Solved it. No need to take the cooling plate off. The themostat probe sits just behind the plate and is secured to the back of the plate by 2 screws. Loosen the screws and the old probe can be released and pulled out from behind the plate. For ease of installing the new probe, tie or tape a thin wire or string to the end of the old probe prior to pulling it out. Installing the new probe is the reverse of this process, using the wire/string to pull the new probe through.
Jun 04, 2009 | Westinghouse Refrigerators
Fridge is on but not cold. thermostat is on right temp but not fridge and freezer not cold at all
See if frost is on rear of freezer panel. posssible defrost heater ,relay, or timer quit.
Apr 30, 2009 | Refrigerators
Freezer and Fridge at wrong temperture
How old is this fridge? Your themostat may be shot. Put an accurate thermometer in the freezer and cooler to ge the real reading. If they are the same as on the door then the themostat is probably the problem. If not, it could be that all you need is a new display.
Dec 17, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Kenmore Thermostat
hi,
order or study the wiring diagram, could be a hi/lo heat setting circuit, the dryer should spin no matter what heat problem, jump the door switch
J
Jul 11, 2008 | Whirlpool LER5636P Electric Dryer
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
