Question about Jabra BT500 Wireless Headset
Where is the on/off switch on Jabra BT500? How do I pair it with my Samsung?
I have BT 500 Jabra Over the ear blue tooth and can't seem to pair it with my Samsung cell. Where's the on/off switch?
SOURCE: How do i reset it?
no answer
Posted on Dec 28, 2007
SOURCE: Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
Posted on Feb 05, 2008
SOURCE: Bluetooth ear set not being detected by new phone
ok, thanks.
Found the problem. As always "Read the instructions first!"
Bye
Posted on Nov 16, 2008
  • 4 Answers
SOURCE: i cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Posted on Sep 10, 2009
  • 638 Answers
SOURCE: Jabra OTE3 won't pair with Verzon LG phone. How do
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Posted on Jan 05, 2010
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    Need operating instructions for Jabra BT 2080 headset
    ok i hope that you are trying to connect the bt device to a phone or game system or computer,the first thing you need to do is turn the power on to what you are connecting the blue tooth device to.your phone computer or game system,next you will have to put your blue tooth device into discovery mode,now most manufactures of blue tooth devices use the power button for this feature,when you turn the power on to your device keep holding down the power button for 6 to 10 seconds this will put your device into discovery mode,usually a light will remain on,then you can search or add new device from what it is you are connecting to,it will ask you for a pin or pairing code,now most manufactures of blue tooth devices use a factory 4 digit pin pairing code,they are as follows,0000,1234,9999,or 1111 enter the code and your device should pair and work with what it is you are pairring it to .i hope this helps
    Feb 26, 2011 | Jabra BT2080 Bluetooth Headset
    Cant get it to woork blue light just blinks
    you have to put ur bt device into pairing mode in order to pair it to a cell phone usually when u turn your bt device on you continue to hold the power button for 6 to 10 seconds and when you have a solid light you are in pairing mode then your cell will pair to your device,it will ask for a pin or pairing code,most blue tooth manufactures use a 4 digit code.the codes to most blue tooth devices are as follows 0000,1234,9999,or 1111.i hope this helps
    Feb 20, 2011 | Jabra BT125 Headset
    CANNOT GET TO PAIR says it is but is not connected
    Hi, It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
    When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
    After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
    there are no special code for pairing Blue tooth device.
    Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
    Hope it helps.
    Thanks for using fixya.....
    Nov 29, 2010 | Jabra Bluetooth Headset with Adjustable...
    I cant pair my jabra bt125 with my nokia n97
    Sep 02, 2009 | Jabra BT125 Headset
    Unable to make or receive calls using Bluetooth.
    try to remove the Jabra Blue tooth that you have under th list of your paired devices. try to turn off the phone and blue tooth then pair it again.
    Jun 25, 2009 | Cell Phones
    Jabra bt500
    yeah charge it for 14 hours......and then hold the pair and call at the same time... then repeat the pairing process
    Jan 04, 2008 | Jabra BT500 Wireless Headset
    Bluetooth from Samsung D900 (HELP PLEASE!)
    nback - DO AHARD RESET *2767*3855#
    KEWL - BUT YOUR BT TO SEARCH SWTCH THE JABRA ON THEN PAIR THE P/W 0000
    Sep 27, 2007 | Samsung SGH-D900 Cellular Phone
    Jabra BT500 Wireless Headset Logo
    35 people viewed this question
    Top Jabra Radio Communications Experts
    Jerry Greenberg
    Jerry Greenberg
    Mohammad Nawaid...
    Level 1 Expert
    Michial Gueffroy
    Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
