Question about Zebra S4M Thermal Label Printer
How do I identify my SM4??
How do I know which of these model correspond to my printer?
S4M-203dpiEPL
S4M-203dpiZPL
S4M-300dpiEPL
S4M-300dpiZPL
Im trying to instal the Zebra Designer Pro and When istalling the CD, the autorun ask me to chose one model. I just know mine is S4M.
  • dansepu Jun 22, 2009
    Nop..!! There is just a serial "number" and and a "configuration"
  • dansepu Jul 02, 2009
    The serial number is 03c08180687 and there is still another number which is called configuration, s4m00-2001-0100t
The "configuration" number is your printer part number. S4M00-2001-0100T means that you have a 203 DPI (dots per inch) printer that is Thermal Transfer as opposed to Direct Thermal. There are at least a couple dozen individual SM4 part numbers. If your printer was a 300 DPI printer, the center section would begin with 300.
Posted on Dec 31, 2009
  • 3 Answers
The configuration code you posted uses ZPL II or XML
Have a good one!
Brian Wallace
Peak Technologies
877-863-2522 x 6807
Posted on Jul 10, 2009
    Sergeant:
  • 220 Answers
Try looking at the bottom of the printer, it should have the detailed model in there
Posted on Jun 22, 2009
  • Claudio Barata
    Claudio Barata Jun 22, 2009
    If you give me the serial number I can try to identify it.
    Whats the serial?
    Cheers
Is there a way to change the setting on the Zebra S4M to rotate the print 180 degrees to match our labels?
No. The change must be made in the software that you are creating the label design in. Let me know if this helps!
Jun 21, 2011 | Zebra S4M Thermal Label Printer
What is the difference between S4M and Z4M
Z4M is the previous model that has been discontinued and replaced by the S4M. Hope this helps!
May 22, 2011 | Zebra Z4M Printer
Hi I am unable to print from Zebra S4M.. while printing the configuration it prints but does not print the test page or the label.
There a number of things that can cause that: 1) wrong printer driver was installed 2) cable to printer is faulty 3) wrong port was selected when the printer driver was installed
Check these and let me know!
Jan 20, 2011 | Zebra S4M Thermal Label Printer
How do i change the media power calibration on a Zebra S4M printer
Go to www.zebra.com and download the S4M pdf user manual. It guides you how to change configuration.
Oct 27, 2010 | Zebra S4M Thermal Label Printer
Zebra S4M Label Printer
Do you know the print speed that you are using? I would slow it down to about 7 ips and adjust the Darkness until you are happy. Some companies want all this speed and the machine cannot do a good job at high speeds (10 ips). If you are not able to over-ride their speed, call them. It will increase your print quality a great deal.
The print speed is the second setting on the menu. Don't forget to save the settings when you are finished (use "Permanent"). Good luck!
May 29, 2009 | Zebra S4M Thermal Label Printer
Jammed S4M Printer
Do what the other guys did and cut the labels and pull it with a set of plyers. Does not seem to be a better way
May 27, 2009 | Zebra S4M Thermal Label Printer
S4M doesn´t print
The S4M comes with either EPL or ZPL programming language installed. (installed at factory) The S600 is a ZPL only printer. Check that you have correctly specified the S4M as a ZPL printer. Print a config label to check. If it is set as an EPL printer contact your supplier and ask him to download the correct programming language. It should only take a competent engineer about ten minutes (If he knows what he is doing)
Jan 20, 2009 | Zebra S4M Thermal Label Printer
S4m menu
The password for level 3 is 1234. The password for level 4 is 9999.
Roberto Martinez
Jul 18, 2008 | Zebra S4M Thermal Label Printer
Printing every third labels ---> not evry
You need to take the labels out.
If you are using the labels that have perforations is where you can tear them off.
What you need to do is to
1) Switch off printer
2) ensure that the ribbon is loaded correctly
3) take some labels, feed them through the mechanism till you can see them coming out from the other end.
4) Make sure that the labels are lined up with the alignment mark or sometimes with label printers there is a light.
5)switch on printer and do a test print
May 08, 2008 | Zebra S4M Thermal Label Printer
Zebra S4M Thermal Label Printer Logo
466 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
