Question about DeLonghi Coffee Makers & Espresso Machines
Delonghi ecam 22.320 how to clean steam wand?
SOURCE: Krups 867 boiler steam leak
Save yourself the trouble, buy a $1.99 frother at Ikea.  Makes the cleaning process easy - that's what I use at home, never used the steam wand on my machine.
To use the frother, just heat up the milk and froth away.  Pretty easy.
Posted on Apr 04, 2008
jonniewalker
  • 1029 Answers
SOURCE: steam wand not working
The steam wand ejects steam in order to froth the milk. The steam wand should be cleaned after it is inserted into milk and at the end of each day. Do not allow the steam wands to soak in water overnight since some of the dirty water can be sucked into the boiling tank inside the machine this may cause the steam not to come out
Unplug the machine, take the case off, disconnect the switch wires and test it with a continuity meter. If you don't get any continuity, or if it is constantly closed and never open, the switch is bad.
this could have been prevented by regular maintenance and proper use. The usual suspect is a gummed up wand or brew line or user error. Here’s what to look for and how to avoid it.
First, notice what kind of wand you have. Most semi-automatic and porta-filter espresso units will have wands that resemble those on bottom or right, although the tips may be different. Some tips do not slide up and down to alter the aeration, as the one on the bottom does. If your wand is from an older (1990s) unit, it could have a more bulbous tip and a smaller hole in the tip. wandte1.jpg wandte2.jpgSome of the new wands give you a manual/automatic control.
wandte3.jpg Many of the new super automatics come with an automatic frothing unit, like this one from Jura-Capresso. The nice thing about the frothing wands on Jura-Capresso's new units is that they allow for even more control.
The "Dual Frother Plus" (top) works like the traditional frothing wand. The metal sleeve goes up for steam, down for foam.
The "Froth Xpress Plus" is a very handy device which can be used with the included sleek milk container or a distinct milk container, like a 1/2 gallon jug. The Froth Xpress has a tube (hard for using the included container, flexible for using a different container) that fits into the frothing tube behind the dial shown in the picture above. After selecting froth or steam, the milk is siphoned into a cup below the steam wand. We recommend steaming the milk first, then adding the espresso.
Whatever sort of wand you have, it is essential to keep it clear of solidified milk which can gum up the tip and even the wand shaft. Here are some symptoms of a clogged wand:
  • Little or no steam comes out of the wand
  • Hot water drips from the tip of the wand
  • A squeal or whistle comes out of the wand when the steam function is selected
  • A deep humming is heard when the steam function is selected*
*This is also a symptom of another more serious problem, particularly if you have a pump espresso machine; so if unclogging the wand does not solve it, you should contact a technician.
A good preventative measure against the clogging of a steam wand is regular rinsing in warm, soapy water of the tip and any other removable frothing part. This should be done after each steam wand use. If your machine has a Froth Xpress, it is important to clean all of the hoses, valve, and connectors (be very careful with the plug, however, because it is delicate). All wands should also have steam jetted through them after a frothing cycle is run.
Another preventative measure is to run a steam cycle for about twenty seconds before each new use. This will eject stray particles before they can build up and cause serious damage. There is also a cappuccino cleaner available which can be used in the automatic frothing devices. The solution is placed in a reservoir, and a full cycle is run until the reservoir is emptied. This can be done every few weeks or every few months, depending upon use.
Aside from prevention, there are treatments for a clogged wand. First, remove the tip, if the tip is removable. Usually they are, as in the case of the plastic tips above. The holes are usually big enough to run a pin or even a small paperclip through (emphasize small) to remove the gunk. If these items are too large, do not attempt to use them; instead try using a thin gauge wire from an electrical wire strand. Next, the metal wand itself can have a pipe cleaner run up into it. Start out by putting just about a half inch of the pipe cleaner up the wand, rubbing it around, then pulling it out. Gradually work more of the pipe cleaner up the wand, but never let the length of pipe cleaner in the wand exceed the wand length. We recommend the pipe cleaners with the stiff barbs attached, as opposed to the mostly soft ones. Do the same for all of the hard hoses and connectors. With respect to rubber or soft plastic parts, rinse them in soapy hot water. If flexible hoses form holes, replacements are available (give us a call) or we've even had some luck at aquarium supply stores.
PLEASE NOTE: if you own the Jura X7 or the Froth Xpress Plus, the diameter of the tiny holes is very important. We recommend trying not to put pins into these holes. However, if they must be cleaned and soaking won't work, a smaller gauge wire, a single strand, should do the trick. Always use a strand that is smaller than the diameter of the hole.
Frothing wand technology is advancing at a breakneck speed, but along with these advances come serious precautionary measures for dealing with these very delicate mechanisms. Follow the steps above, and your machine should be producing full-fledged froth for its entire life.
Posted on May 26, 2008
When I got my X1 (used,) the steamer was clogged. I unscrewed the end of the nozzle, and a big chunk of calcium(?) came out. I had to poke it with some wire with the steamer on. The way I got the end off is: I wrapped it with a leather glove first, then turned it with a pair of pliers. I still managed to scratch it a little bit though. Maybe you can turn it by inserting a needle in the little hole on the side of the nozzle. I've been thinking of using distilled water to avoid the calcium build-up in the future.
Posted on Oct 08, 2008
  • 3 Answers
SOURCE: Steam wand not working
BEFORE YOU DO HAVE IT REPAIRED TRY SOAKING THE WAND IN BOILING WATER THE MIKE SOMETIMES CLOGS IT UP AND THE ONLY WAY IS TO SOAK IT IN BOILING WATER I PUT A CUP UNDER IT AND JUST HOLD IT WHILE IT SOAKS THEN JUST LET THE STEAM DO THE REST
Posted on Mar 25, 2009
  • 14 Answers
SOURCE: Starbucks Barista Espresso Maker
This is a general comment for people having problems with leaks and pressure in their espresso machines. If you do not used filtered water, the minerals and other materials suspended in the water will bond to the moving parts and tubes of your machine (e.g.: scale). The problem will be worse if you live in an area with particularly hard water. In some cases the pressure pipes can get completely blocked and if the pump is powerful enough, the pipes can rupture, otherwise, the pump will simply not put out any water. The solution is to regularly flush out the system with descaler. The frequency of cleaning depends upon how often you use the machine. You can get descaler from any decent coffe place (like Starbucks), an appliance repair place, or the hardware store. I use CLR which is sold at hardware stores. CLR stands for Calcium-Lime-Rust, and it effectively cleans all of these and is cheaper than specialty scale removers. Simply dilute some in water and pour the mixture in the machine, then cycle the pump and run it through. Collect the spent liquid and run it through again 4 or 5 times (or more if you've never cleaned your machine before...) Allow the liquid to sit for 10-15 minutes between flushes so that the solution has a chance to eat away at the scale. Once you have done this a few times, flush out the machine thoroughly with clean water 4 or 5 times, using CLEAN water each time you rinse. If you want to get an idea of the scale that has been removed, keep a small amount of the original clean solution in a glass and then compare the spend cleaning liquid with unused cleaning liquid to see the difference. The spent liquid should be foggy/muddy compared to the clean stuff and if you let it sit, the scale will settle to the bottom of the glass and will be clearly visible. You can prevent some of the buildup in your machine by using filtered water as they do at Starbucks.
Posted on Jun 05, 2009
Steam is not strong on my ec702 delonghi. I have cleaned the wands. The wand spits out a lot of water with a strong steam, bu the steam gets weaker as I am trying to froth.
The steam temperature control (Thermostat) is not functioning.
The small quantity you get at the start is the steam pressure build up with hot water. Water steam cannot keep up the pressure.
Replace the steam thermostat.
Dec 24, 2016 | DeLonghi Coffee Makers & Espresso Machines
May 26, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
Espresso part is working, hot water/steam draining into drip tray.
I had the same problem on my Delonghi ESAM3300; you need to replace the "Tap" #7313216621 you can buy at eReplacementParts.com and search on how to install on Youtube. Its easy. No more leaking. Good luck
Oct 07, 2015 | DeLonghi ESAM3300 Magnifica...
How to do an hard reset for DeLonghi ECAM 23.450 ?
There isn't such a thing as hard reset on this machine. You can turn on test mode and test machine functions.
http://s-coffee.ru/dt/ecam23.450.s.pdf
Feb 16, 2015 | DeLonghi Coffee Makers & Espresso Machines
Steam wand pops off
You are correct in associating the pop off is relative to the pressure. If the steam wand as you called it comes free when pressure builds, the problem can be the wand is damaged, not completely free of debris, or misaligned. I suggest you contact the company directly and have a technician run you through some tests to locate the problem.
Mar 25, 2014 | DeLonghi Coffee Makers & Espresso Machines
Delonghi EC702
Even semi skimmed milk with froth if hot enough. Check the steam temperature, you may need to blow steam through the milk for longer.
Mar 06, 2014 | Coffee Makers & Espresso Machines
Ecam remove infuser
Hi. Need more information, but it sounds like you need to remove the brew unit and clean it. There is a door on the side of the machine that allows you remove the brew unit. remove it and clean under hot water. Dazza REPAIRER
Sep 24, 2011 | DeLonghi ECAM 23.450 S Espresso Machine &...
Plastic on steamarm blew off
Those pieces (2 of them) are suppose to come off. The outer sleeve turns 1/8th of turn clockwise looking down on it and then can be slid down. The inner slides off and has a flat spot on the back to line up with the steam wand, it's held in place by an o ring. All can be ordered through Delonghi.
They are designed to be removable so they can be cleaned after each use.
Before replacing any other parts, try descaling your machine. Build up will cause heating and steaming issues.
Aug 23, 2009 | DeLonghi EAM3400 Espresso Machine
DeLonghi EAM3400 Magnifica with broken steam spout
No offense to Irishwarrior but the answer to your question is yes, you can buy a replacement. Call Delonghi. The inner sleeve has a flat spot on the back that matches up with the steam wand. No glue, and o ring holds it in place, either the o ring is worn out or the hole in the bottom of the sleeve is partially clogged creating more pressure than the resistance of the o ring. A paper clip straightened out will "****" it out. If you need to replace the whole steam wand arm you would want to order a new "tap" valve. Delonghi can give you the # of an authorized service center where you can order one (Delonghi will not sell you "internal" parts)
Feb 28, 2009 | DeLonghi EAM3400 Espresso Machine
Coffee Makers & Espresso Machines Logo
81 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
