HP Printer Error 0X610000F6 also known as Carriage Jam Error occurs very often in the Photosmart HP Printers. When a jam occurs in the printer due to paper scraps or due to any other reason, the printer stops working and it doesn't print any document.
Couple things: Look inside a printer with flashlight and make sure there is nothing in the way. Remove printhead and see if error goes away. See this video where printer has similar code and is fixed:
Take out all error cartridge..u find small chip in all cartridges.its counter/ detect chip.clean n make it shiny by wipeit wid Normal eraser.fix back n check if nr. Buy new cartdg
Hi, do note that even if you are printing in black, the printer requires that you have installed functioning cyan (blueish), magenta (reddish) and yellow cartridges as well.
you may need to change the com port that the printer is using, it may be in conflict with some other hardware. Go to device manager and click on printer and right click go to properties and see what com port it is on., check other hardware and make sure nothing else is running on the same com port.
You may also try re-installling the software.
The problem centered around the fact that the HP209 would only print 8.5X11 sheets from Greeting Card Factory. Any other size seized up the pring spool.
We're going to return the HP (We think it's defective) and get an Epson.
