Question about Electrical Supplies
Can an intermatic t104 or t104r replace a t104p
  • 112 Answers
SOURCE: Intermatic T104R clock not working.
here is a link to the wiring diagram, u may not have the clock motor hooked to the right terminals. http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
Posted on Aug 21, 2009
  • 112 Answers
SOURCE: How to check if Intermatic T104R clock motor is
here is the link to the wiring diagram, hook the motor up without it being installed and see if it runs, make sure u have power on the terminals.
SOURCE: How to wire a intermatic timer T104 240 v to a
T104 is 240volt timer.
Timer has terminals A 1 2 3 4
T-104 clock motor must receive 240Volts to operate.
Clock motor wires are white-colored and can be seen connected to terminals 1 and 3.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/images/Back-of-WH40-2b.jpg
There are two work-arounds for using T104 for 120V.
1) Diagram 1 showing how to change wiring:
http://waterheatertimer.org/images/T-104-control-120V-Load-500.jpg
Move 240V clock motor wires to terminal 1 and A.
Connect 240V Hot leads to terminals 1 and A. This will power the 240V clock motor
Hot wire going to 120V load connects to terminal 2. This wire will be turned on each time timer turns on, and 120Volts will power the 120V load.
To complete 120V circuit, neutral wire that comes from neutral busbar in breaker box connects to 120V load.
To control additional 120Volt circuit, run jumper wire from terminal 1 to terminal 3.
Connect Hot to second load to terminal 4.
2) Second method is to change T104 timer into T103 timer:
http://waterheatertimer.org/images/T-104-control-120V-Load-2-5.jpg
Replace T104 240V clock with identical 120V clock motor from Grainger
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
Neutral wires connect to terminal A.
Hot wire from Breaker connects to terminal 1
Hot going to Load connects to terminal 2
Posted on Dec 27, 2010
SOURCE: Hello I have a Intermatic Model
Sounds like you need new T-100 series 240V clock motor.
T104 is 240volt.
Buy clock motor at grainger:
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK2?Pid=search
Add a comment if you need install instruction.
Clock is on back of mechanism.
Mechanism snaps out with thumb spring located at top inside the box.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Posted on Jan 12, 2011
gotgeek2
  • 565 Answers
SOURCE: Where can I buy "stops"
The trippers can be obtained here:
http://www.aplussupply.com/intermatic/timer.htm
Scroll down just a bit.
Posted on Feb 23, 2011
How connect a new intermatic t104r 120v
T104 timer is 240Volts.
Not 120Volt
You can convert timer into 120V by changing clock motor from WG1573 to WG1570. This action will convert the T104 into T103.
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
The T104 timer can be wired many different ways:
Copy following link for illustrations showing both T104 and T103 wiring
Add a comment with specifically what you are connecting to timer, and I will comment back with more detail as needed.
Oct 07, 2012 | Intermatic T104R 208-277Volt 40-amp Timer...
HOW TO SET INTERMATIC T104R
Open following link for instructions how to set T104 timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
The T104 is 240volt timer, and the R suffix means timer is inside raintight indoor/outdoor enclosure.
Jun 14, 2012 | Intermatic T104 24h 208-277v Mechanical...
Can an Intermatic T104P3 Timer Model be replaced by a Intermatic T104D89 Timer Model.
T104P has plastic box.
Any T104 mechanism will snap into that same plastic box.
So you don't have to change boxes.
If you are buying T104D89 with metal box, the timer mechanism is same as T104P.
Both are 240V and both wire the same.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 04, 2011 | Garden
I need trippers for a paragon electic model # 4014-20 swimming pool timer
1) Paragon no longer makes timers and parts, except defrost timers.
4014-20 is not defrost timer
http://waterheatertimer.org/Paragon-timers-and-manuals.html#Paragon4000
2) 4000 series uses X2772 tripper
Google search for this product shows these trippers selling for 50-60$
3) Intermatic cross-reference chart shows T104R 240Volt raintight is replacement
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
I saw T104R at Lowes today for around 90$
4) How to wire T104:
5) Add a comment for more free help.
For a price, fixya expert speaks with you over phone while you work on timer.
We are always less expensive than a service call.
Jan 14, 2011 | Hardware & Accessories
I have intermatic t104 time 24 hour, the door hinges are broken can i get new door.
Page below shows Intermatic boxes, but doesn't describe which timer fits which box.
And the box costs as much or more than new timer.
http://www.electricsupplyonline.com/prod/intermatic-timer_accessories.php
Amazon sells T104 indoor
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/B000BQOX88/ref=pd_cp_hi_3_img
T104R raintight sold at Aplus
Jan 05, 2011 | Intermatic T104 24h 208-277v Mechanical...
Electrical Supplies Logo
268 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
