Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
How do i take out the drip pan
It wasn't freezing therefore the fridge part stays luke warm. I tried to clean the condensor but could only get the front of it. I checked the evaperator their was about 2 inches of frost on it. I got the ice off then took off the panel. when i exposed the evaporator it was a solid block of ice. I let it defrost over night ,now i want to get to the rest of the condensor to clean it and take off the drip pan n, but it seems to be alot of unscewing to get to it.Is what i did enough or should i start unscrewing.Is their an easier way to get to it .It is a kenmore bottom freezer fridge.Model#596.69874000, 596.669879991, 596.79872991, 596.79874000, 596.79991
    Sergeant:
  • 340 Answers
Keep unscrewing Kenmore is areal pain to clean use a vacuum long soft bristle brush @home depot
the best way is with high pressure air down side to that is dust all over 2. you have a defrost problem Have it checked .Tom
Posted on Jun 22, 2009
Kenmore coldspot 106.53769202 will not cool fridge, have deg=frosted,vacuumed underneath and emptied drip pan, no air blowing into fridge. Had gnats inside while power was off for over a month.
Does the compressor run? Does the small tube get warm? is the inside fan working? does it have an outside condensor fan? Is power getting through the thermostat due to gnats between the contacts? Does the inside light work? need more info.
Oct 16, 2013 | Kenmore 50522 / 50524 Side by Side...
Samsung refridgerator freezes due to clogged drain line.
I would look for bad door gaskets. Sounds crazy but if you have bad gaskets, you will let in more moist air and the freezer will freeze up faster. If the fridge is freezing up I would look at the slide from the freezer to the fridge and see if it is stuck open. During the defrost cycle the unit should drain and fill the drain pan, but the normal operation of the compresser should be able to evaporate the water with ease. Look at the door gaskets and the vent. Good luck
Sep 08, 2012 | Samsung RS2556 Side by Side Refrigerator
Freezer keeps freezing up. But the fridge doesn't stay cool.
the reason the fridge doesnt stay cool is because the freezer keeps icing up, try defrosting the freezer and try cleaning the condensor coils and this may help.
Mar 15, 2011 | Refrigerators
Freezer is freezing, but ice box is not cold. Told to clean fan. Where is the fan located?
Remove the grill along the bottom of your refrigerator. Locate the drip pan, using a flashlight if necessary. The pan should be sitting on a set of black condenser coils.
Remove the pan and wash it. Use a mixture of warm, soapy water and bleach to kill the mold.
Reinstall the pan and the grill.
Locate the coils. They look like thin, black radiators and may be underneath the fridge or attached to the back.
If the coils are on the back, pull the refrigerator away from the wall, then vacuum the dusty coils, using the brush and crevice attachments. Reinstall the refrigerator grill.
If the coils are underneath, pull off the grill and remove the drip pan. Vacuum the dusty coils, using the crevice attachment to get between them. Take care not to damage the delicate coils. Reinstall the refrigerator grill.
Feb 25, 2011 | Refrigerators
Do I need to empty the water from my drip pan
the pan is there to catch condensation from the compressor during the refridgeration cycle. the water build up to me indicates one of two things. Either the refrigerant level is low and it is freezing up then thawing, or if you have ice or water dispencer it could have a leak in the line. the only thing other than that is a leak in the magnetic door seal or other insulation causing condensation. hope this helps
Jun 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
Samsung RS2545SH coils freezing
Hey how's it going? I may have the info you need, but first I need you to go through a check list to see if there is a simple fix.
Check to see if there are any obstructions in the freezer drain (freezer drain located inside freezer compartment behind back panel lower right hand corner of the freezer coils) if there are obstructions or debris remove and clean with a mild dish washing detergent and water, check to see that water can drain freely. see if this helps.when the coils freeze is the ice flaky or is it frozen solid ice? if the ice is flaky it could mean that either the refridges/freezer door are left open to long "check your door gaskets or seals by closing the on a dollar bill if it pulls out easily with little to know resistance your door gaskets may need to be replaced. After you defrost the freezer coils did you notice if there was water in the condensor pan, if so good sign. (condensor pan: is the pan that collects the water that drips through the drain hole of the freezer compartment caused by the heating of the coil by the coil heater: water that enters the pan collects and is reused by the condensor fan by blowing warm air partly into the water and through the condensor coils causing them to cool.)if you still need to test your bi-metal therostat or your glass heater/ice pipe heater, you will need a multimeter and knowledge on the use of it.(IF YOU 'RE NOT NOT COMFORTABLE AROUND ELECTRONICS AND ELECTRICITY PLEASE CONTACT A QUALIFIED REPAIR SERVICE AND REMEMBER TO UNPLUG APPLIANCE BEFORE ATTEMPTING ANY REPAIRS) for more info on how to test please reply,Good Luck, be safe..
Aug 21, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridge
ok pull the cover off the back wall of the freezer compartment where the evaporator fan is after look under the evaporator should see an aluminum pan with a hole there that's the drain hole for the defrost system if its frozen and that hole is stopped up then every time it defrosts the water will run in the freezer and freeze and also drip into the fridge remove the ice and clear the hole also check the drain tube in the back to make sure its clean
Jan 18, 2008 | Refrigerators
I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Jun 04, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
183 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
