Question about Maytag MSD2454G Side by Side Refrigerator
MY MAYTAG FRIDGE SERIAL #MSD2758DR
THIS WAS GIVEN TO ME SO I HAVE NO OWNERS MANUEL, THE FRIDGE WONT GET ABOVE 60 DEGREES, NOT SURE WHAT THE PROBLEM IS. FREEZER IS GETTING WARM NOW TOO. PLEASE HELP!!!
    Sergeant:
    Champion:
  • 208 Answers
The refrigerator needs serviced bye a refrigerant expert there's a valve in that closed system needing replaced and the refrigerant may need recharged . but beyond that i would inspect the area aroiund the compressor and bloswer to make sure nothings blocking it unplug the fridge and let it set for a day then plug it back in .Did the fridge get layed on it's side ? if so it should be allowed to set for at least 24 hours
Posted on Jun 22, 2009
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
MAYTAG SIDE BY SIDE MSD2356AE. FREEZER NORMAL TEMP. FRIG. 60 DEGREES.
make sure that there is nothing blocking the flow of air coming in. the fridge is cooled by the air in the freezer. also you might think about replacing the relay on the compressor. it may be going out.
Aug 11, 2008 | Maytag Refrigerators
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Jul 30, 2014 | Maytag Refrigerators
Msd2756de fridge side wont cool
all of the above solutions are correct evaporator fan going bad causing the ice to build up defrost timer getting stuck or heating element for defrost not working...good luck
Mar 16, 2014 | Maytag MSD2756G Side by Side Refrigerator
Freezer works but fridge doesn't stay cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag RSW24EO refrigerator not cooling
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 14, 2009 | Refrigerators
Ice freezing up on bottom of freezer and water puddles in front
Two possibilities, ice maker leaking or the defrost drain is blocked with ice or another object. Unplug the freezer and remove the rear panel in back of freezer. At bottom of the evaporator coil is a tray that catches the defrost condensate and sends it to the pan beneath your refrigerator to be be heated by the compressor and fan heat produced from the condenser. The moisture is then returned to the air inside your home. If the drain is blocked with ice or anything between the freezer and the pan below, the condensate tray will overflow will end up inside your freezer or fresh food compartment. Questions? I will be here to help you, Let me know, Sea Breeze
Jun 23, 2009 | Maytag MSD2758G Side by Side Refrigerator
Freezer works fridge doesn't both worked yesterday today fridge wont
Hi, Check and see if the condenser fan motor down by the compressor is running. Sometimes when they get moved, something will get into the blade and stop fan.
That will overheat the compressor and cause it to shut off on safety. If that fan is running, check the fan inside freezer and look to see if frost is building up on inside rear freezer wall.
Please let me know if this helps you or if I can assist you further.
Vic
May 30, 2009 | Refrigerators
Fridge is not cooling
You probably need an adaptive defrost control which is located in the back right hand corner of your fresh food compartment. You have to dismantle the overhead controls to get to it. If you had to defrost your coils, and the heaters test good, then you probably need the above control.
Apr 06, 2009 | Maytag MSD2454G Side by Side Refrigerator
Maytag MSD2454G Side by Side Refrigerator Logo
196 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
