Question about Ariens Zoom XL 54"" Zero Turn Lawn Mower 915173"
Why will my Ariens Zoom XL 54 not start with a newer starter and battery
Put a new starter on last night and the mower will not start.
  • 306 Answers
SOURCE: I just purchased a used Ariens sport zoom 1440.
Change the oil and air filter. Look for grease fittings on all moving parts and give them a shot.
Posted on Apr 30, 2009
SOURCE: blades won't turn to cut grass
On the chute where the grass comes out there is a black piece of metal under the edge of the deck held on by the 2 big thumb screws is probably bent. You will need to try to move the blade on the side near the chute by hand (Make sure the mower is not running when you do this) if the blade touches the black piece of metal it will kill the mower if you engage the blades and try moving forward. Anyway you need to take the black metal piece off and bend the corner out of the way (I used a crescent and clamped it to the hitch on my pickup). I am guessing i went over something like a street curb with the deck when it was to low and that bent it. Now when ever I move the mower from someones yard or drive it across the street I always raise the deck up all the way. I hope this helps
Posted on May 27, 2009
  • 430 Answers
SOURCE: I neglected to run my Ariens 5524 snowbower dry last spring.
No, just spraying gumout in the carb will not likely help. You will need to remove the carb, disassemble it and clean it. I suggest replacing the needle, bowl gasket and bowl nut gasket. Be sure you have cleared all passages in the carb.
Posted on Dec 21, 2009
SOURCE: Mower wont start.
I have a 927 series rider and just put a new battery,and spark plug.Has spark and still wont start. What else can I try?
Posted on May 30, 2010
  • 18 Answers
SOURCE: I have an ariens zoom 1540 hydrostatic mower. One
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered.
Posted on Jul 09, 2010
Key won't fit into ignition
Perhaps the key is bent? Maybe you need to order a new switch and key online. It would help to know what you're doing to try and get it to insert, or even the make and model of the mower.
Aug 23, 2016 | Ariens Zoom XL 54"" Zero Turn Lawn Mower...
How to change the oil
at the base of the dip stick tube there is a quarter turn black nipple push it in and turn it you can add a hose to the end to help it drain into a pan without the mess
Sep 24, 2012 | Ariens Zoom XL 54 In 24 HP Kawasaki Zero...
How do I reset my oil life meter on a xl 54
Most of these service minders cannot be re set, they will re set them selves after so many hours.
Jul 24, 2012 | Ariens Zoom XL 54 In 24 HP Kawasaki Zero...
Hi, i have a Ariens Zoom M 2148 xl tractor model
Probably you can get what you need at a lawn mower shop, they have exploede parts diagrams on microfilm.
Sep 28, 2010 | Ariens 34 In 344 CC Briggs Stratton...
Ariens tractor has new battery and won't turn over to start - what could be wrong?
couple things to check start by checking the starter itself then check the starter switch... good luck
Apr 03, 2010 | Ariens 34 In. Zoom Series Riding Mower
I had a problem with the battery about 1 month ago, I replaced the battery and it was working fine. I tried to start it today and the engine turns over but it wont start. After trying several times, the...
OF course if you keep turning the engine oner,the starter is going to get hot and start smoking.Its not the battery thats the problem,it sounds like you may have a carb problem or maybe just need a new spark plug
Jan 10, 2010 | Ariens 34 In. Zoom Series Riding Mower
I have a 2005 ariens zoom 22/50 and it won't start. Battery and starter are new. Both work (tested) It doesn't seem to turn over. half a cycle and boggs down.
more info would be nice. did you check the oil ? may be too much oil in motor ,(may be gas in base) change oil if needed. remove plug or plugs,ground them, try starter now. (if there is gas in base, your float may be full of gas,"sinking",replace float", ) if motor still dosn`t turn, try removeing all drive belts,and try again.
Dec 13, 2009 | Ariens Garden
Bad battery or starter
Hook a known good battery out of another vehicle or take the leads off of your mower battery and hook a set of jumper cables from your car battery and see if it turns over hard still. Does the mower run good once started or does it not start at all because of the slow starting?
Sep 08, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens Zoom XL 54"" Zero Turn Lawn Mower 915173" Logo
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
