Question about Whirlpool Duet GHW9150P Front Load Washer
The washer makes terrible noise when it spins
I can move the stainless steel drum easily
  • 530 Answers
Do you mean up and down? or when you turn the drum like you are spinning it?if it makes a sound like an airplane takeing off or a train rolling through your house. you have a bad bearing which is a very exspensive repair.
Posted on Jun 22, 2009
You may also have an article of clothing stuck between the two drums. You will have to reach your hand in between the two and feel around to see if something is stuck. I found this solution on another site after my washing machine also was making a horrible noise during the spin cycle, which was also accompanied by water spewing out of the dispenser drawer based on where the article of clothing was stuck. Good luck!
Posted on Jul 05, 2009
My LG washer makes a horrendous noise when it in use. what could cause this?
Open door and see if you can move inner tub without the outer rub moving. If you can the 'spyder' which hold inner drum to axel hub is broken. Post results in comment section
May 21, 2018 | LG Washing Machines
Bosch Maxx wfl 1300 washing machine - drum making loud squeaking noise.
sounds like bearing have failed or the stainless steel drum has detached from its carrier open the door and try to move the drum up and down there should be no movement at all if there is machine will need to stripped down
Mar 03, 2014 | Washing Machines
Loud clunking noise during wash cycle
Hi What machine is this? and is there play on the stainless steel inner drum?
Mar 11, 2013 | Washing Machines
Is it normal for liquid to be present in the top part of the drum?
Yes I have this type of washer and it has the water in a ring at the top of the drum to help balance it out during spin, not quite sure why but yes it should be there. The gargling sound you describe could also be the balancing hooks that attach the drum to the top of the washer which sometimes make strange noises but there fine.
Mar 10, 2013 | Haier RWT350AW Top Load Washer, White, 3.0...
Drum appears to float and move up and down very easily, top pary of stainless steel drum seems exposed behind teh rubber gasket
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 06, 2010 | Kenmore 43042 Front Load Washer
I have a kenmore Elite front loading washer and yesterday during a load it made a terrible noise and when the washer was opened two of the fins inside the stainless steel tub had fallen off and now when...
u will need 2 replace all the baffles .remove top when this done on top of tub u will see a plug removethis . if u notice on the new baffle there is a place for a screw, that screw hole can b acessed through the hole in the top. the factory never puts these screws in the noise I dont know about. haundi24
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
Loud grinding noise only during the spin cycle.
Try looking at the solution for loud noise during spin with gray water in drain. This also sounds like the bearings on the shaft supporting the stainless steel drum, in the aft half of the outer drum.
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Terrible noise on spin cycle, stainless drum is loose inside plastic tub, wore the front half of the plastic tub down due to friction. Took washer completely apart, found the spider arms cracked. It...
Just had the same problem 1 month ago. My Whirlpool Duet front load made that terrible noise. 2 of the 3 spider arms were cracked. I hade a new hole tub with the spider arm and the shaft , because it is 10 years limited waranty . But if it is not under waranty it costs about 270$ for that tub you can buy it from many appliance parts web sites on the net. Good luck, huge job to all remove that thing
Dec 03, 2008 | Washing Machines
Makes a noise like there are rocks or coins when it spins
If it is thumping... you have a broken spider on the inner stainless steel drum. Major defect with this machine. You'll need to call to get a new washer tub assembly... comes complete with inner stainless steel drum and outer plastic drum already assembled and ready to install. Good luck.!
Jul 01, 2008 | Frigidaire GLTF1670A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
432 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
