Question about Samsung RS263TDBP Side by Side Refrigerator
Samsung fridge not cooling?
The drawer temp is fine but the shelves are not cooling
SOURCE: samsung rs21dcns fridge freezer Ice
Found an electrical drawing and resolved the issue - Broken cable
Posted on Nov 11, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
tborn6
  • 700 Answers
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Posted on Dec 24, 2008
tborn6
  • 700 Answers
SOURCE: Samsung fridge RS27KASW not cooling
whats happening is that the refrigerator side appears to be frozen up. what hte controller is doing it's showing yopu the actual temperature inside take everything out og ]=f the refrigerator and thaw i out. then don't pack the frig so that the air can circuate around the food real good.
Posted on Mar 07, 2009
SOURCE: Fridge temp set to 38 is blinking,,reset unit
I had a similar problem, paid a technician $90 to tell me to defrost the entire unit for 15-20 hours, and now it works like new. It is supposed to self defrost, but with poor circulation in the freezer (simply caused by too much stuff in there) the unit frosts up. This caused a rising temp in the freezer leading to inconsistent temps.
Anyone reading this with a similar issue, save your money and defrost it overnight. You should see a pool of water in the bottom of the freezer after defrost if this was the problem.
Posted on Aug 12, 2010
Fridge not cooling; fridge temperature staying at 19c. power cool button not changing the temp.
On these models the technicians want to sell you circuit boards and other parts. These parts usually do not solve the problem.
First to get your fridge cold again. Remove all the drawers and shelves on bottom of fridge side and remove
rear panel to inspect coils. If coils are covered in clear ice like a solid block, then thaw/defrost this. A hair dryer helps.
Pour hot hot water into this area when finished until it runs out the drain at the back of fridge. The frozen solid drain is the problem. When finished use blocks to raise front of fridge so it leans slightly back. Supposedly this helps the drain from freezing again. The product is inherently defective and designed poorly, your problem is quite common.
We completely redesigned the drain on ours (not recommened for most people) and it works okay but I cannot wait to replace with a different brand.
Jan 23, 2011 | Samsung RS2534 Side by Side Refrigerator
We had to pull our kenmore 22 s-b-s away from the wall to replace the water filter. while unplugged and empltied, we removed drawers and shelves to wash. wheeleed out onto patio (always rewmained upright)...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 19, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Water under vegetable drawers
Look on the top back of ur fridge. in the middle of it u should see a resetacaple. if it is full of water and over flowing there is ur problem. then u have to check about ur cooling unith if not change the setting of u fridge let the frizzer frezze and the fridge stay a bit warmer
Nov 19, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
I want to use my undercounter wine fridge as a real fridge. Wher can I get replacement shelves and baskets/drawers. U-line large model
This cannot be done. The doors are not designed to be as a refrigerator door. The controls are different. This model is designed to be 45 to 60 degrees. WILL NOT WORK FOR REF TEMPS!
The liner has racks that is screwed into them. Shelves are with liners that are molded so the shelves are resting on them.
Sorry
Jul 07, 2009 | Refrigerators
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Refridgerator is not cooling properly
Ours does this too; it says its 34 degrees but really its 53-58 degrees. . . The compressor coolant part of the machine freezes and then it can't circulate the cold air to cool the fridge. You have to unplug it for at least 24 hours to let it thaw, or you can take out the lower drawers and shelves, unscrew and remove the lower back pannel (from the inside of the fridge). We use a blow dryer to thaw out the ice block that formed on the unit. It goes faster if it is unplugged, this fridge is horrible we lost hundreds of dollars in groceries before we figured out the problem.
Dec 26, 2007 | Samsung Refrigerators
The refrigerator side is not cooling.
ALMOST DEFINATELY YOU WILL HAVE AN ELECTRONIC CONTROLLED AUGER(MOTOR)CONTROLLING THE AMOUNT OF CHILL ENTERING THE FRIDGE COMPARTMENT. IF YOU SET THE FRIDGE TO MINIMUM AND LISTEN CAREFULLY, THERE SHOULD BE A SOUND INDICATING THE AUGER IS WORKING.( OPENING AND CLOSING THE FLAP). SET TEMP. TO MAX AND LISTEN. IF NOTHING, IT COULS BE A DEFECTIVE MOTOR OR FAULTY THERMISTOR(TEMP. PROBE).
Aug 08, 2007 | Samsung RS2556 Side by Side Refrigerator
Fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
May 16, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Samsung RS263TDBP Side by Side Refrigerator Logo
46 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
