No error code 61 listed, only a 66 error code which indicates lamp issues:
66
A) Lamp did not turn on at P-ON sequence... Check CJ4 circuitry
B) No Lamp Inserted............... No Lamp inserted
C) Disconnected cable between ballast and lamp.... HV connection or lead wire to lamp.
D) Lamp-Enable goes to PWB-MAIN but not to Ballast....Lamp Cartridge Failure
I would think that the item to check would be the power supply. You will have to take the TV apart, get the board part number and see if you can find a replacement for it. I would recommend putting a meter to it to verify it is the board that is bad.
This is an LCD projection tv- there is no color wheel, have your tv serviced- cleaned, hopefully you dont have optical block issues. contact a service shop.
No.The tv have a colors wheel is dead.The colors wheel make loud motor noises,squiling noises and flashes picture with black&white.The colors wheel is dying and spinning off of it motor axis.Hire a Tv Tech. to change the colors wheel.Because is require take out alots machanical parts,before u can even come to the colors wheel itself to replced.
