Question about Toshiba STA10WINPOS - America, St-a10, Touchpos W/ Winpos
Wp k833 My printer install successfully but not printing any thing plz help me?
In WP my print button is not highlighted so I can print a document. Can anyone help?
This sounds like a driver problem.
I suggest you disconnect your printer from the system, delete it from the Control Panel, restart the computer, turn on the printer, then connect it (USB?) to the computer.
Win should recognize that 'new' device and locate the right driver for it.
If it fails to do this, you should try downloading a new driver from the Net for Win 7 and whatever printer brand/model you have.
If the driver is not able to self-install, you will have to go back to the Control Panel and take the 'Add new device' path.
Good luck-
Oct 14, 2014 | Microsoft Computers & Internet
LAN connection gestetner 10512
connect the local area network cable to the port of the machine .
press the counter key
press system settings
press the interface key on the screen.
enter the ip aderess and other necessary things in the portions provided the machine.
now go to your computer and open printers and devices.
click on add printer
select add network printer.
enter the ip aderess you entered on the machine and the computer will communicate with the printer and it will will be installed automatically.
print a test page .
if the test page comes out successfully, you have successfully installed the printer.
you can now print your documents form that machine.
good luck.
Feb 13, 2014 | Gestetner 10512 Printer
I have a printing problem not printing from my Dell Laptop
ur printer driver is not installed on u r laptop or it is in correct driver of printer if u r using windows then go in printer and devices and chk u r printer is installed and it is set as default printer or plz clear all things to me u r printer model and operating system
Feb 02, 2013 | Office Equipment & Supplies
Hello, I have a printer and I'm trying to install it. My printer is HP LazerJet 1020 and I used it before but for some reason I just can't print!
Hi there !
Have you installed successfully your printer software and print a test page if its working? Or was successfully install but cannot printer any thing? Are you install on directly to your computer or using a lan network? This printer can be installed easily with no problem. I believe that you had problem with the usb driver.
Jan 09, 2011 | HP LaserJet 1020 Printer
My printer is not taking any command for print out. its scanning successfully, but not taking any printing command..plz help
has your printer ever had this problem?
is it a new printer?
Check your cables and make sure the are plugged in an secure.
You can also unplug your printer for a minute plug it back in and observe what happens.
If this does not work check you system tray in the bottom right hand corner of your computer screen.
look for the printer icon and click on it. Cancel all print jobs and retry your printing.
this may help solve your issue
Mar 26, 2010 | HP PSC 1401 All-In-One Printer
When i am going to installation printer the give me error operation could not be complete plz. help me
please do the below things and try to install ...
ensure that you have admin rights in the system
restart the print spool services ( to restart the print spool goto start ...run type services.msc press enter then go for print spool service double click on that and stop the service and restart again )
connect the printer to the system and switch on it then try to install the printer ......
Dec 08, 2009 | Canon MultiPASS C70 All-In-One InkJet...
Printing problem
Dear sir,
install new oparating system and attach data cable in your pc then show a new hardware .
This printer is auto plug &play not driver requarments.If you are not success then change data cable with new one.
Thanks
Aug 24, 2009 | HP LaserJet P3005n Printer
Help with printer!
Does it ask you to print a test page or anything when you installed it?If it does, you needed to do that before you try to print anything else.
Id uninstall it then reinstall and see if that helps. Remove all plugs connecting it to pc and put them back in-that may also solve things.
Jun 20, 2009 | Lexmark Z600 InkJet Printer
Recurring "cartridge successfully installed" message
Download the Kyocera Driver Deleter tool from here:
http://drivers.softpedia.com/progDownload/Kyocera-KM-Deleter-281031-Download-18304.html
Run the tool and delete the driver for your HP. Disconnect the printer, then use Add/Remove programs to uninstall the HP software.
Reboot.
Reinstall the HP software and reconnect the printer when prompted by the software install.
After this I didn't get the message again.
Hope this helps!
Mar 18, 2009 | HP Officejet 7210 All-In-One InkJet...
Unable to print or only prints one page
My brother dcp tells me
unable to print check troubleshooing and maintenance chapters.
I have done this and cleaned the printer, it also tells me ink jets empty, they are all new ones.
Driving me mad any suggestions so I can get my sanity back.
Thanks
Denise
Jun 12, 2008 | Paxar Monarch 9855 Thermal Printer
Toshiba STA10WINPOS - America, St-a10, Touchpos W/ Winpos Logo
41 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
