Question about Konica Minolta bizhub Office Equipment & Supplies
I print a copy there are meganta & cyan thik line in printing what is problem?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Id say magenta and cyan drums are bad if I had to guess. Whats the model? Whats the life count on your transfer belt?
Posted on Nov 14, 2014
SOURCE: copies print with horizontal lines
thin lines? spaced about 1.5 inches apart could be toner left on the drum, take the cartridge out turn it over and retract the shutter, manually turn the drum using your thumbs on the edges of the drum, do you see thin lines on the drum? sometimes something sticky gets on the drum attracting toner and then it transfers to the paper during the copy process
Posted on Dec 21, 2007
  • 14 Answers
SOURCE: hp 4600 no cyan printing
Firstoff, if you have tray 1 set to "any size" & "any type" they had problems with it going into calibration to frequently. If you upgrade the firmware this will take care of that. As for no Cyan, check the scanner interlock to insure it is opening the scanner cover. You could also go into diagnostics and disable cartridge check and swap the cartridges around, ie. cyan & magenta, run the print quality pages and see if the problem follows the cartridge. It could also be HV power supply.
Posted on Jun 19, 2008
  • 12 Answers
SOURCE: iP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Posted on Jan 21, 2009
jonb3838
  • 237 Answers
SOURCE: HP Laserjet 3390 Prints a Black Line on papers
make sure you check and make certain there are no scratches clean both the top of the scanner and the scanner bed itself and wipe down with a lint free cloth
Posted on Feb 12, 2009
  • 52 Answers
SOURCE: cyan ink prints in stripes parallel to print head motioin
try cleaning the nozzles
Posted on May 23, 2009
Printer is not printing yellow, Light Cyan, Cyan, blue lines through Light Magenta & Magenta, What could be causing this and it is also leaking black ink out of the bottom of printer.
Is it under warranty, are you re-filling the cartridges? If yes to first and no to the other two, send it back under warranty. If you use copy cartridges or refill old ones the warranty is vod. This means you need to replace the printer. To be honest, you'd be better off buying an Epson all in one. Even the wireless model start @ sound 40gbp and you can buy good copy cartridges from choicestationery.com
Nov 17, 2014 | HP Photosmart C8180 All-in-one -...
Bizhub C654e Color Copy Only show Cyan or Magenta Lines
So you have tried all the calibration tests? It sounds as if the alignment is off. If that isn't the case, you can try setting the copier back to default settings. I think in this make the reset button will be a tiny indented hole on the back.
Elisa Jed ' http://stores.abmcopier.com/canon-color-pre-owned/
Apr 13, 2014 | Office Equipment & Supplies
Thick lines
Check the fusing unit and or transfer belt. Does it print OK not copy! Print Ok means internal OK then check the scanner section
Nov 11, 2013 | Minolta MF1600E Plain Paper Laser Fax
Trying to copy and nothing printing. Ink levels are good, paper is coming out
Perform "clean print heads" in printer properties select printing preferences,service then click clean nozzles, perform twice or thrice then do the nozzle test, if print heads are recovered your will be in safe, other wise***Two print heads are in this printer each print head leads two colors, left print head leads black & yellow and other one leads cyan & magenta. You need to replace the print heads based on the color which missed.
Jan 03, 2012 | HP Officejet 6500 Wireless All-in-One...
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
Cyan cartridge not working
You have to replace the cyan cart with a new one. error should disappear.
Even though you didnt use cyan the machine needs some ink to keep the noozles wet. Therefore machine does some automatic cleaning cycles which consumes some ink.
BTW: did you program the date/hour settings? Do so and do NOT disconnect machine from constant power, because data will be deleted. machine will do its cleaning cycles about every 2 weeks. otherwise it will do the cleaning everytime its powered up!
Dec 12, 2007 | Brother MultiFunction Center MFC-440CN...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
