Question about Masterbuilt 20070106 Electric Smoker
Grill element elements 9907079003 - Masterbuilt 20070106 Electric Smoker
2 Suggested Answers
  • 54 Answers
SOURCE: ESBMPG Grill: i need a heating element where can i get one?...
If you can't go to the Manufacturer I don't think your going to find one.
Posted on May 20, 2010
Can I get replacement for the heating element model 200700106 serial GA040909
The element kit is Part # 9907079003. So first try Masterbuilt 1.800.489.1581, as they use this same element in a couple of different models. My primary source for grill & smoker parts, Appliance Factory Parts, says it's no longer available. So Masterbuilt may be your only source. But, to be very candid, that's iffy, at best. Masterbuilt is not known for having critical parts for their smokers.
I hope this wa of some help to you and thanks for choosing FixYa.
Jul 24, 2011 | Masterbuilt 20070106 Electric Smoker
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
The grill (Upper Oven Grill Element) in the oven is not working, I realized the 4 wires at the back that connect to it are all loose. Can i fix it by connecting them myself? is it something dangerous or...
With 4 terminals, it sounds like a double grill element. But it could also be a single grill element with a second oven element. If the spade connecters are loose they need to be tightened first. Get a pair of pliers and gently squeeze the terminals until the gap reduces so when it slides on it will be tight. Do you know what wires go where? If so reconnect them. If you don't do the following;
As you look at the element terminals they should run horizontally. Look at the element inside the grill compartment. From left to right, the no. 1 and no. 4 terminals should be the same element and the no. 2 and no. 3 terminals should be the other element. If this is correct put the 2 neutral wires, in any order, on terminals 1 and 2 and the active terminals on 3 and 4. This should work. You just have to check the correct element comes on when you operate the grill/oven controls.
Feb 18, 2011 | Smeg Ovens
Creda Concept Solarglo Cooker. Grill not working. Elements seem ok as top oven works fine. Any ideas gratefully accepted! Thanks in anticipation.
Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
Feb 11, 2011 | Ovens
Grill element not working on rangemaster 110
If grill element not working, switch power off and remove back panel to gain access to wiring. Grill element will be toy element. look for any burnt wire, either blue or brown. Re attach where broken and reassemble. If you have any doubts call a technician. Not to difficult though.
Jun 05, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
The element on my grill inside the oven is not heating up?
There are two possibilities of what is wrong here.
One is that the grill element has failed and may need to be replaced.
Second it could be a failure in the grill element control circuit (in effect the temperature regulator) thus not allowing power to the element.
Most likely it will be the grill element.
You would need to test with a multimeter to determine which a) by checking the resistance reading of the element and then b) the continuity of the control circuit.
Jan 20, 2010 | Zanussi ZHQ575 Electric Double Oven
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Hi - I have a creda solarplus cooker (48349) - I wish to replace the 8 bar grill element with a 4 bar grill element - can you please advise me of the steps necessary to do same - yours michael clancy
It’s basically as simple as:
Turn off the gas supply to the range.
Turning off the mains power to the range.
Remove the back panel behind the grill.
Remove the 2 power connectors to the grill element.
Remove the earthing wire to the element screw terminal.
Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your range.
Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
Reconnect the earthing wire to the element screw post.
Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
Reconnect the power cables to the element.
Reconnect the power and check that the element works correctly.
Disconnect the mains power again and replace the rear panel(s).
Reconnect the mains power and recheck that the grill functions correctly.
Turn on the gas supply.
Oct 05, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Rangemaster Toledo 110 oven/Grill element
How easy is it to fit a new grill element. The element on the left hand side of the grill is not working so I need to replace this. I'm just wondering if this is easy to do myself or do I need an
electrician
Regards
Sandra
Dec 15, 2007 | Kitchen Ranges
Masterbuilt 20070106 Electric Smoker Logo
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
paulcarew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
