The power jack on the motherboard has disconnected and need to be reattached. Is there a user manual covering this problem?
  • lesnil Jun 22, 2009
    The problem was not with a printer. The problem is with a Compaq presario laptop 2500.
    Yes Thanks
Would this be regarding the mothering within the printer or within your computer? In either way, please let me know the make and model of the printer or computer.
Regards
nLinked
Posted on Jun 22, 2009
  • Anonymous Jun 22, 2009
    Appologies for the typo, I was supposed to say motherboard instead of mothering.
    According to the service manual, it looks like the AC power jack has been soldered to the motherboard. You'll need to remove the motherboard and power jack, and install a new AC Power Plug. This is not a simple task. The solder will need to adhere to the right connections on the motherboard. The traces on the motherboard are very thin, and if you accidentally melt one it would probably damage the motherboard.
    As requested, there are two service manuals available for this item here and here.
    Best regards
    nLinked
Computer will not power on regardless of being plugged in or not, and overheats within just a few minutes
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Overheating can be caused by faulty memory or a faulty motherboard. Disconnect power, remove the battery and remove the memory cover. Remove all memory modules and insert one at a time to test. For motherboard issues, you'll need a local professional to resolve.
Hope this helps.
Oct 21, 2011 | Acer Aspire 5050-3242 Notebook
The Yellow Port That's In The Inside Where You Plug The Charger in has Broken And Is Very loose And I can reattach It. When I Plug The Charger In The Battery Wont Charge The Whole Thing Wont Come on...
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled & the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 01, 2010 | Acer Aspire 3680 Notebook
Dell Inspiron 1501 wont power on (no power-on light), nor gives any indication of starting power-on. Power adapter blinks when connected to laptop, but stops blinking and stays lit when removed from...
This seems like there is a device causing this problem. Disconnect the battery, hard drive, optical drive, hinge cover, keyboard, palm rest.disconnect the above devices one after the other and check the functionality each time. You can find a service manual at www.support.dell.com from the left click on manual, when opted choose your model and follow the service manual. This should help you. All the best.
May 29, 2010 | Dell Inspiron 1501 Notebook
How to replace D620 power jack? pwer jack is "loose" causing intermittent connection with power supply. the problem is "not" power cord.
The power jack is located on the motherboard. It is soldered to it. You have to remove the screws behind the laptop securing the back cover and disconnect the hard drive and GPU cables remove the keyboard so that you can pull out the motherboard. This is necessary since the solder joints are located under the motherboard and the jack is over it. There are 3 pins that are soldered. Remove the solder on all 3 and pull out the jack. Insert the pins of the new jack in the space vacated by the old pins and use a low diameter solder(2mm or less if available and lead free solder only) to solder the pins to the board and voila!
May 18, 2010 | eMachines eMD620-5133 Notebook
System won't start, power retries every 1-2 seconds
Make sure your smps power supply of cpu is working fine.
Make sure motherboard is not ground with cabinet cover.
Pull cmos cell from motherboard for 10 minutes then put it into it's position.
reattach the RAM memory into slot also make sure ram is fine.
Clean dust from all parts.
Reattach processor and it's fan.
Reconnect pci card or vga card if any.Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
May 03, 2010 | Intel Motherboard
How to open the evo 500 compact black box
Hi maybi,
The evo's have two senarios that you may be facing.
First is Smark Cover locking. If you enable the Smart Cover Lock and cannot enter your password to disable the lock, you will need a Smart Cover FailSafe Key to open the computer cover.
You will need the key in any of the following circumstances:
Power outage
Startup failure
PC component (for example, processor or power supply) failure
Forgotten password,
If you don't have the Key, To obtain a FailSafe Key:
Contact an HP reseller or service provider.
Refer to the HP's Web site (www.HP.com) for ordering
information.
Call the appropriate number listed in the warranty.
To open the computer cover:
1. Turn off the computer and any external devices.
2. Disconnect the power cord from the power outlet, and disconnect
3. Using the Smart Cover FailSafe Key, remove the two
tamper-proof screws that secure the Smart Cover Lock to the
chassis.
4. Remove the Smart Cover Lock.
To reattach the Smart Cover Lock, secure the lock in place with the
tamper-proof screws
Or the non- Smart Cover Case:
1. åWARNING: Before removing the computer cover, ensure that the
computer is turned off and that the power cord is disconnected from the
electrical outlet.
2. Turn off the computer and any external devices.
3. Disconnect the power cord from the power outlet, and disconnect
4. Press in the button on each side of the front bezel to release the
quick release cover latches.
5. As you slide the computer cover forward, release the buttons and
allow them to return to the original position, then lift the cover up
and off the unit.
✎ To replace the cover, reverse this procedure.
f7b910a.jpg Good Luck,
Mark
Oct 16, 2009 | Compaq EVO 500 DT/MT S478 P4 Motherboard...
Reattach Power LED, Power SW, and HDD LED leads
go to the manafacturer website, there should be plans for the motherboard somewhere on there
Nov 24, 2008 | Gateway MS-6389 Ver.1 S462 Motherboard...
Open cover to resolder power jack
You will need to remove the system board to gain access to the power jack. Here’s the link for the Inspiron 2200 service manual: http://support.dell.com/support/edocs/systems/ins2200/en/SM/index.htm
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 2200 Notebook
Nc6320 external power problem
most case cause DC jack connection is not stable or damage
you may try
1) to open cover find out the DC jack 2 or 3 pins on the motherboard then to fix it use iron and flux.
2) check any disconnection DC/DC circuite near the jack
3) repleace the new jack if the jack damage
Oct 26, 2008 | HP Compaq nc6320 Notebook
44 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
