Question about Canon Pixma iP4500 InkJet Printer
Pixma 4500 service mode - Canon Pixma iP4500 InkJet Printer
How do i find info on duplex printing on a canon pixma 4500
This model Canon printer does not have a duplex unit and cannot print double sided printing automatically.
DOUBLY SIDED PRINTING WITHOUT A DUPLEX UNIT
Open your Word document.
Open page 1 - then Print the current page.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will be printedon the other side of the page 1).
Repeat this procedure for the other pages.
May 03, 2012 | Xerox Phaser 4500/B / Phaser 4500/YB Laser...
I cannot fix the problem Error code 2 & 7
Manual Reset for Canon Pixma MPC190 Printers
1. Enter the service mode SERVICE MODE - pressing buttons Menu, Copy, Scan, Copy, Copy
2. Choose TEST MODE.
3. Select 8 PRINTER TEST -TEST MODE.
4. Choose 3, EEPROM CLEAR
5. Select 0, INK COUNT
6. Press the Set button.
7. Click Stop / Reset button (return to item 3), and again press the ON / OFF
Aug 11, 2011 | Canon PIXMA MP190 All-In-One InkJet...
The absorber is full
1 Enter the service mode SERVICE MODE - pressing buttons Menu, Copy, Scan, Copy, Copy
2 Choose TEST MODE.
3 Select 8 PRINTER TEST TEST MODE.
4 Choose 3, EEPROM CLEAR
5 Select 0, INK COUNT
6 Press the Set button.
7 Click Stop / Reset button (return to item 3), and again press the ON / OFF
This should fix the issue
Mar 02, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Ink absorber
  3. Select 8 PRINTER TEST TEST MODE.
Mar 01, 2011 | Canon PIXMA MP190 All-In-One InkJet...
My printer's ink absorber full.
Hello
Although the software resetter for the Canon Pixma MPC190 printers has available on the internet but before using the software you must reset the printer manually. But manual reset can not reset the counter printer permanent, to reset counter permanent require software resetter such MPTool or Serive tool software. Reset for Canon Pixma MPC190 Printers Enter the service mode SERVICE MODE - pressing buttons Menu, Copy, Scan, Copy, Copy Choose TEST MODE. Select 8 PRINTER TEST TEST MODE. Choose 3, EEPROM CLEAR Select 0, INK COUNT Press the Set button. Click Stop / Reset button (return to item 3), and again press the ON / OFF Good Luck
Feb 26, 2011 | Canon PIXMA MP190 All-In-One InkJet...
How do I get into "service mode"
Try pressing and holding the power button for 30 seconds. If this does not work do the same with the "up" arrow for 30 seconds. One of these shouyld take you to service mode.
Aug 11, 2010 | Eiki LC-XB42N 4500 ANSI Lumens XGA Manual...
Pixma ip 4500 printing pic too pink
Try and find calibration options somewhere in settings of printer. Use them to adjust print colours. Good Luck
Apr 28, 2010 | Canon Pixma iP4500 InkJet Printer
I have a canon printer ip 4500. It says it has a service problem 5100. i turned it on and off three times it still comes up service problem. What should i do?
5100 is service error. just follow this steps to fix this,
1. Hold RESUME then press & hold POWER
2. Release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
for reset waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 17, 2010 | Canon Pixma iP4500 InkJet Printer
Canon IP4500 service error code 6502
canon pixma 4500 service error 6502
Jul 15, 2008 | Office Equipment & Supplies
Canon Pixma iP4500 InkJet Printer Logo
15 people viewed this question
old marine
old marine
