Question about Samsung SCX-4725FN All-In-One Laser Printer
Where is the fuser unit - Samsung SCX-4725FN All-In-One Laser Printer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 167 Answers
Open thru back cover
Posted on Oct 02, 2015
How do I change out the fuser fixing unit on a Kyocera FS3900 DN
1. Draw the rear unit.
2. Insert a flat-blade screwdriver to push the
fuser lock (gray colored) on the rear unit and
the fuser unit is separated from the rear unit
(rails).
Do it both ends of the rear unit.
3. Check or replace the fuser unit and refit all
the removed parts.
Place the fuser unit on the rear unit (rails)
and push the fuser lock so that the fuser
lock catches the fuser unit.
Do it for the both ends of the fuser unit.
Aug 08, 2014 | Kyocera Mita FS3900DN Fuser Fixing Unit -...
E studio 520 code c447
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0." also 447
Jan 17, 2014 | Toshiba Office Equipment & Supplies
Error code c43
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jan 14, 2014 | Toshiba Office Equipment & Supplies
Call for service C 430
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Dec 31, 2013 | Toshiba estudio 255 Copier
TOSHIBA E STUDIO 207 ERROR C 44
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jul 08, 2012 | Toshiba E Studio 207
Printer prints out but all powdery and wipes of page .
I agree the fault is almost cetainly with the fuser unit.
Oct 30, 2011 | Samsung CLX-3170FN All-In-One Laser...
Paper is stuck under the thermal unit and cannot be removed. The unit probably has to be removed to get at the paper and we need instructions how.
First you must remove the cover for the duplexing drawer below the fuser drawer. It will allow you to fully extend the fuser drawer to remove the fuser unit. You have to remove the 3 front covers of the fuser drawer, remove the three black screws that secure the fuser motor, then the yellow cover to access then two screws that secure the fuser unit to the drawer. But you must unplug the connectors you see in front of the fuser unit. I believe there are 5 connectors that need to be unplugged. Don't forget to unplug the connector below the fuser unit. This is the sensor that tell the fuser shield its home position. You fully extend the drawer by looking at each side of the drawer and push in the leaf springs you see and pull the drawer out further. Remove the two screws you see on the top of the fuser and gently remove the fuser unit. Take your time and all should go well.
Jan 15, 2011 | Canon imageRUNNER 5570 Copier
Put in newer fuser unit but machine still says to replace
If you want to clear the fuser message you have to be sure you replaced the fuser web. Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
May 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Big noise
If the printer was not making the noise before you replaced the fuser unit I would try the following:
1. remove and re-seat the new fuser unit and try a test print.
2. if it still makes noise, remove the new fuser unit and replace the old fuser unit and try a test print. (if you waited untill the printer refused to print on the old fuser this might not work).
If you don't get the noise with the old fuser, then it's possible that the new fuser is defective. You could try returning it for replacement at this point. If you still get the noise with the old fuser, then possibly it is not seated correctly or the latches aren't locked or there is some other unrelated issue.
Jun 25, 2008 | HP LaserJet 2420 Printer
Samsung SCX-4725FN All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
