Question about Samsung SCX 4200 All-In-One Laser Printer
Where is the fuser on Samsung SCX4725 printer
Samsung printers
This error is a fuser malfunction. You will need to replace the fuser unit in order to get this running again. A fuser unit will run about $90 for a refurbished unit. You should check the manual for more error codes: Samsung SCX 5635FN Manual
Mar 27, 2014 | Samsung SCX-5635FN All-In-One Laser...
On samsung ML-2955ND message is fuser unit failure
replace the fuser
http://www.precisionroller.com/fuser-assemblies---units-for-samsung-ml2955nd/details_73486.html
Jan 11, 2013 | Samsung ML-2955ND Laser Printer ML-2955ND
I got problem with printer samsung scx4725, one part need to be replace is pick up roller, and next to it 2 plastic tab, oneis one missing. Pls tell me where can I download part. Thanks a lot!!
Try to clean the roller with alcohol first; it worked for me with the SCX4521-F and If you have already done it, search through google (sorry I don't know your'e region)
good luck
Nov 06, 2010 | Samsung SCX-4725FN All-In-One Laser...
Samsung CLP-650N Engine Fuser Inverter Error 3
the fuser and dave home drive got to be repalce.
most likely it has worn out.
May 10, 2010 | Samsung CLP 315 Laser Printer
Samsung clp-300 Error message is "fuser low heat error
The problem is that the Fuser is not heating up. Its possible you have a broken heat lamp.
The Fuser will have to get replaced, if you want to spend less but more labor, the heat lamp can be ordered.
Mar 07, 2010 | Samsung CLP 300 Laser Printer
Samsung scx4725 cant scan from network but can print fine.
Actually I figured it out. I called Samsung and they said that this printer does NOT support scanning over ethernet, only USB. Pretty lame but you get what you pay for.
Aug 14, 2009 | Samsung SCX-4725FN All-In-One Laser...
Samsung CLX Printer printing unevenly
it is possible that this is a fuser prob, fuser works applying heat and pressure, if the roller, either the pressure roller or the fuser roller is defective this is most likely will happen too, you might want to  check the number of copies or prints made
Mar 22, 2009 | Samsung CLX-2160N All-In-One Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
37 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
