Question about Sharp AR-5320 Black and White Copier
Sharp AR5320 Photocopier blinking H4 - Sharp AR-5320 Black and White Copier
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Enter sim 14
Posted on Apr 21, 2016
VOTIT
  • 2071 Answers
SOURCE: Driver for 5320
click below;
View Full Version : DRIVER NEEDED: Sharp Electronics Sharp AR-5320 (Windows XP Home)
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Jul 30, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Copier Driver for Sharp
Click here to get the file downloaded
Posted on Jul 31, 2008
  • 3 Answers
SOURCE: error h4
it is on you fusing unit of your copier, check the fuse maybe it is open already and need for replacement... H4 means that your heater lamp is not functioning
franklin
Posted on Feb 03, 2009
  • 990 Answers
SOURCE: Sharp H4 Error message
Hello sir; The code need to reset;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 then press start.
3, if machine work, please don't forget to give me a good rating.
THANK YOU !!!
Posted on Feb 12, 2009
007tech
  • 95 Answers
SOURCE: My sharp ar-5316e photocopier displays H4. what should i do
The H4 means "Heat roller low temperature detection"
Basically the fuser is not reaching a specified temp within a specified time frame. There are several causes/posibilities :
Thermistor abnormality
Heater lamp abnormality
Thermostat abnormality
Control Board PWB abnormality
or it is just a one glitch and it can be reset.If re-seting the copier does not work then it could be something physically wrong.
To clear error go into SIM mode by pressing the following keys one after the other "#" "interupt" "C" "interupt" (must be in copy mode to start off). enter 14 and start key. Confirm if requested to do so. copier must be restarted when this is done. Do not play around with any other settings in SIM mode.
If error persists then one of the above items is at fault. you could pull out the fuser unit and open it up to check for any dirt/debris buildup around the thermistors/thermostat.
Hope this will help.
Posted on Apr 10, 2009
Sharp z380 photocopier - display blinking H then 4?
H4 is a fuser lamp, or a fuser component. If you need a fuser, look on this website: www.fusers.com
if the fuser is not found, then give them a call or send a comment and they will find you one and a price.
Oct 25, 2010 | Sharp Office Equipment & Supplies
Sharp a163 photocopier ero u2 40 and h4
U2 40 is a CRUM comunication error with the toner (wrong toner chip on toner cartridge or wrong toner cartridge) try a new toner.
H4 is a fuser trouble code. Check to make sure all conection are right, Theres a few posible problems for H4, power board, MCU board, thermistor, or broken heat lamp.
Aug 30, 2010 | Sharp AR-160 Copier
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
How do I clear F2 and H4 on Sharp photocopier
F2 means wrong cartridge installed, could be a bad cartridge. H4 is a low fuser temp error. try resetting by pressing "#","interrupt","C","interrupt. then press"1","4","start". then turn off/on and see if it clears. if not you will need a tech.
Nov 12, 2009 | Televison & Video
My Photocopier displayed error H4 on the screen
Dear sir
H4 signal is fuser unite problem please call a technician they solve this problem.Just we serve problem location because i am not live your area.
Thanks
Tareq
Aug 12, 2009 | Sharp Office Equipment & Supplies
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
Error h4
franklin
Jan 07, 2009 | Sharp AR-5320 Black and White Copier
I need Driver to install Sharp AR5320 to my vista Home Basic
the sharp does not offer the vista drivers for this product, you can check it yourself by visiting the sharp site mentioned below:-
http://esupport.sharp.at/html/driver/DataOutputDetail.php?TemplateLang=en&ID=300
Dec 31, 2008 | Sharp AR-5320 Black and White Copier
H 4 FLASHING, MANUAL LOST, AL-1220 Sharp Photocopier
Try to press #, Interrupt, C, Interrupt in that order and enter 14 then press copy key.
Oct 20, 2008 | Sharp AL-1000 Laser Printer
Sharp AR-5320 Black and White Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
