Question about Drills
DC24SC charger repair - Drills
I would like a new charger Ryobi bc-1807t charger and 2 batteries. or a repair to my charger
home depot -lowes -most hardware stores--go online to buy the replacement for repair do a search for tool repair store in your area but might be cheaper to do replacement
Sep 09, 2016 | Ryobi Drills
Repairing Charging cord on Braun shaver cord
no--simply because there are live wire connections to the transformer that people will touch and then seek compensation for that carelessness
best if you junk it and simply buy a new charger
Jul 10, 2016 | Braun Syncro 7526 Electric Shaver
Schumacher charger parts
Probably not worth repairing. Meaning, the cost to repair will most likely exceed the value of the charger.
Sep 04, 2014 | Schumacher SCUSE826 SE-82-6 6 Amp 12V...
I have an invacare ride on . The battery charger failed after the storm. Are they repairable or do I need a new one. If so, how much do they cost
The battery charger for this scooter is available from:
http://www.monsterscooterparts.com/
I believe the original equipment charger from Invacare for this scooter was a 3 Amp off board or on-board charger. The charger is no longer available from Invacare. Monster scooter parts shows this as a 2 Amp charger for the Lynx.
It would be more expensive to repair this charger than to replace it since you indicate it failed after a storm power surge. You will be happier by replacing the off-board or on-board charger for a price between $50 and $150. The only cost effective charger repair is the cord or plugs.
If the charger was plugged in during the storm, I would check the power path on the scooter for burnt fuses and wiring. Hope this helps.
Dec 30, 2010 | Invacare Supply Group Invacare Scooter...
How to fix or repair a panasonic 12v cordless
it realy depends on what kind of charger it is, if it has a coil or a switch mode charger, switch mode chargers have ic's in them and changing them or even getting them may be very hard, if its a coil type check output on coil as its likley to be that they have a built in thermal cut out fitted witch burns out, if they get over heated,,,
Dec 06, 2009 | Cameras
Charging
Then there is a problem in the charger socket. Try a different charger from a friend to eliminate the charger. Does your charger work elsewhere?
Aug 14, 2009 | Nokia 6120 classic Cellular Phone
Charger not recognized
Folks.
The issue with most of the Dell charger issues rekated to a new charger not being able to charge the battery is the fact that Dell has a screwy proprietary circuit design in their laptops and chargers.
It seems that the Dell laptops are designed so
only Dell chargers will work. While other
brands of chargers will power the laptop when plugged in,
they will not charge the battery.
They do this so they have a monopoly on their chargers and thus can charge a frickin' fortune for their, Dell chargers.
Want them to change this? don't buy Dell products for a while. If enough people ban them, they would change this **** overnight!
Jul 07, 2009 | Dell Inspiron 1501 Notebook
Drills Logo
54 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
