Question about HP VP6311 Bulb
Hp vp 6311 reset lamp - HP VP6311 Bulb
Power led is blink 4 times so how can i mentain?
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
means the lamp may be fault,and other parts is working well
Lampdeng.com
Oct 08, 2015 | Electrified Replacement Lamp with Housing...
How do i reset timer on marantz projector VP 4001
Hello
you want to set the Lamp timer after replacing the Lamp I thinks and posts this solution.
[1] Connect the power cord into the AC socket of the projector.
[2] To reset the Lamp timer; While simoultaneously hodking down "MENU, ENTERAND DOWNWARD Button" on the projector, press "POWER/ 'STANDBY/ON on the projector.
* "LAMP 0000H" is displayed indicating that the Lamp Timer is reset.
If you want anymore assistance from me, get me by FixYa. OK.
Sep 19, 2011 | Marantz VP4001 DLP Projector
I just replace a lamp on Sony vpl-cs20 and lamp timer is still high
You should turn on the VP-CS20 with the button on projector, NOT THE REMOTE or the instructions wont work.
Using the remote commander while the unit is powered up, press "ENTER", "ENTER", "LEFT"
and "ENTER" in sequence. A prompt will appear on the screen asking if you wish to enter the factory mode.
Press the "UP" key on the remote and the unit is now in service mode. This sequence will add two new groups
to the customer setup menu. Press the "MENU" button to view.
Whenever the lamp is replaced, the lamp timer should be reset. With the unit in the "factory" mode, press
"RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to zero in the service menu.
Hope it helps,
FVazquez
Sep 22, 2010 | Sony VPL-CS20 Multimedia Projector
How do you reset it after replacing bulb?
Hi, there are two methods for doing this, one is through the menu and the other is by holding buttons to reset the whole unit's settings.
Method 1:1: Plug in the projector and turn it on.2: Press Select [info] 3: Press Lamp Timer Reset4: Reset the lamp indication.
Method 2:1: Place the projector in Standby mode.2: Hold the SOURCE and ASPECT button for at least 5 seconds, make it 10 to be sure.3: This will reset the system including the lamp hour timer and take you back to 0.
Hope this works out well for you,
Let me know if you have any further problems.
Paul
Nov 11, 2009 | Olympus VP-1 Multimedia Projector
No display from projector
try resetting the lamp timer. if that doesn't work: listen for a high pitched whir when you power it on. if you don't hear it, the colorwheel needs replacing. if you do hear it and it doesn't light, the ballast is bad and needs replacing.
Aug 10, 2009 | HP Digital Projector Vp6110 Multimedia...
Disable track pad when using the mouse on advent 6311
Do you want to disable the onboard touchpad while you use an external mouse?
To do this there should be a key sequence on the laptop like Fn+ F8 (or another key) it has a mouse symbol on it.
May 11, 2009 | Acer Aspire 3680 Laptop
The machine is projecting a very purpe/pink image.
check the WB, or else reset the camera back to factory default using the menu
Sep 30, 2008 | Olympus VP-1 Projector Lamp
Hp vp 6210
connect the laptop with projector and power up the projector and select the input 'computer' now start the laptop. the Projector will automatically detect the signal. secondly also chek with the display setting set to 800x600 then check with higher resolution.
Mar 28, 2008 | HP VP 6210 Multimedia Projector
Lamp off
Hi there
Your Projector is overheating , check if all the fans are running.
I can almost guarantee you that one of the fans is faulty !
Mar 23, 2008 | HP Digital Projector Vp6120 Multimedia...
HP vp 6120 Projector
Hi there
Have you reset the lamp timer ?
If you have and the problem stil occurs you will have to replace the Ballast ( lamp's powersupply ) This is a very common problem with this specific HP model.
Dec 29, 2007 | HP Digital Projector Vp6120 Multimedia...
HP VP6311 Bulb Logo
79 people viewed this question
Seeker5211
Seeker5211
