Question about Panasonic SC-HC3 Mini Stereo Audio System with iPod Dock SC-HC3 Shelf System
How do I gain access into the unit it just stopped working
Nothing is working in my oven not even the led timer is lighting up
When the timer, clock etc didn't light up my oven stopped working. Replaced the clock display unit and all is now fine. A simple switch over just remove one wire at a time and place it on the new unit, the only difficult part was gaining access to remove the display unit itself.
Sep 08, 2015 | Ovens
How to change fuse
If it is an over the range unit then the front control panel will come off and you can gain access to the fuse. A wall unit panel will open up and again gain access. If it is a counter top unit. the case will have to removed and you will gain access to the fuses. Now what tripped the fuse. It could be a bad door switch. a shorted high voltage capacitor or it may not be a fuse at all it could be the flame sensor tripped or the magnetron sensor. Some over the range units have a sensor that will shut it down if the stove gets too hot. look for burned connectors. be very careful of the high voltage circuit and make sure the power is off.
Oct 12, 2014 | Microwave Ovens
3 plates stopped working and the 4th one does not switch off.
unplug the unit and gain access to the wiring connection for all 4 elements(plates). remove the wiring from the element that will not shut off. while making sure none of the unconnected wires do not touch any metal or another wire, and plug in power cord. if the 3 non-working elements get hot then replace the none working control knob
Apr 03, 2014 | Stoves Kitchen Ranges
1996 ford f150 front gas tank gauge reads empty but tank is full pump in front tank was replaced about a year ago what could problem be
When pump was replaced, did you also replace sending unit? It is usually a good idea to replace sending unit when replacing pump. The sending unit also "sends" information about the fuel level to your fuel gage. It is also possible the float on the sending unit is stuck in the low fuel or empty position on the sending unit. Although on some vehicles you can replace individual parts of the fuel delivery system, it is usually a good idea to replace all the internal parts of the sending unit assembly at the same time. After all, most fuel tanks can be a real pain to gain access to the inner workings of the fuel delivery system, so why take the chance of having to gain access again.
Good luck.
Jul 23, 2012 | 2005 Buick Terraza
How do I open a Triton shower box ?
there are usually screws on the top and the bottom of the shower unit holding the front cover on.
Apr 11, 2010 | Home
Bad Fuel Level Sending Unit
You have to remove fender deck to gain access to the fuel sender.Once thats done you have to remove sending unit from tank and with ohm meter connected to black and black/white wires see what your resistance is between terminals when moving float up/down.Reading's should be between 6-200 ohm's,If it's not,replace sender.Also with sender out,key on,move float up/down and see if gauge move's.
Nov 21, 2009 | Garden
I have an LG DLE2532W dryer. It suddenly stopped putting out heat. I've heard that there's a heat regulator switch that can trip if the unit overheats located underneath the barrel. What's the easiest...
You r correct. Take top off. Take control unit off. Take front off. Search how to videos online, YouTube, repairclinic.com, appliancepartspros.com
Jun 05, 2017 | LG DLE2532W Electric Dryer
My wireless HP prn stopped working suddenly with NetGear router
You need to go into the netgear router settings online with a computer that is attached to the router. You enter this:192.168.0.1 in the address bar to gain access.You need to know your username and password to gain access to the menu. Then check the wireless settings to see or change the passphrase. Good Luck
Jul 11, 2009 | Computers & Internet
My Panasonic The Genius microwave just stopped working not getting any power to display. Wondering if it is the fuse and where that would be located.
HI, if this unit is totally dead, this may be a power inverter issue. there is a fuse located on this board inside the unit. you will need to gain access to this board and fuse by removing the outer cover. there should be a few screws on the outside of the microwave to remove.
Check the In-line fuse for its value. if the fuse is good, replace the power unit(inverter board)
Jun 20, 2009 | Panasonic Microwave Ovens
Directionals stopped working
If you have no turn signal operation check the turn signal flasher unit. More often than mot this will be the problem. Your emergency flashers operate on another circuit with another flasher unit. The flasher units are very cheap to purchase and easy to gain access too.
Feb 09, 2009 | 1988 Pontiac Sunbird
Panasonic SC-HC3 Mini Stereo Audio System with iPod Dock SC-HC3 Shelf System Logo
52 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
