Question about Boating
How do you shift into reverse on a 1990 evinrude vro 120
4 Suggested Answers
centralvalle
  • 386 Answers
SOURCE: engine was flooding out\now fuel primer has to be used to run
recheck float level as well as needle and seat for sticking and or damage, just crack line to bleed air , and eventually it self bleeds anyway... also unless you replaced with new floats check float weight with a float scale to see if floats are saturated or have fuel inside making the heavy and inaccurate ...
Posted on Aug 04, 2009
  • 53 Answers
SOURCE: in the control box of an evinrude 115 vro v4
The warning horn on a V.R.O. system ( variable ratio oilier) warns you of three problems. (1) LOW OIL. means the remote oil tank in the boat is near empty or empty(2) NO OIL. means there is no oil getting to the V.R.O. .problem is, clogged line or the diaphragm in the V.R.O is blown.(3) OVERHEAT. means the engine is overheating. The V.R.O is you lift and pressure pump for fuel and oil. plus it mixes the oil and gas to proper ratio. Three warning, three senders. LOW OIL sender is in the remote oil tank in your boat. NO OIL sender is in the V.R.O.. and the OVERHEAT sender is on one or both cylinder heads of a the engine depending on the year model
Posted on Nov 04, 2009
SOURCE: 200 evinrude will not shift into reverse when boat
Yes check the shift rod at the shift linkage. First Check the pin from the shift rod at the base of the power head.
Posted on May 10, 2011
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views ยท 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
Evinrude 120 vro outboard floods easily on startup , could spark plugs be wrong type
No,check vro fuel pump diaphragm.if primer bulb doesn't get hard when priming is a sign of needle and seat not sealing or a hole in fuel pump diaphragm.
Sep 08, 2013 | Sierra International 18-4310 Marine...
How do i disconnect shift rod from 1994 60 hp johnson vro
You may be able to find more information on the boating forums.
http://forums.iboats.com/johnson-evinrude-outboards-24/
Mar 17, 2013 | Boating
I have a Evinrude Ficht 135 that Runs Ok but won't go in to gear, forward or reverse. Any ideas?
Disconnect the shift cable and see if the problem is with the shift box or the lower unit. If the lower, remove the bottom plug and look for water or metal where there should be clean oil.
If the shift box, take to the marina- they were a bear. Even just for cables.
Jun 17, 2012 | Light Boating
Need a downloadable owners manual for evenrude out board motor model # 55975c
Hello Santos.
Give this site a try.
http://the-manuals.com/johnson/evinrude-outboards-vro-70-manual/
Or if you do not find what you are looking for you can try several from this page.
http://www.google.ca/search?q=evinrude+manual+55975c&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
I hope you find what you are looking for.
KL
May 01, 2010 | Boating
In the control box of an evinrude 115 vro v4 is an alarm why does it go off every 15-20 min when the motor running
Sep 02, 2009 | Boating
Engine was flooding out\now fuel primer has to be used to run
Aug 04, 2009 | Boating
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
