Question about Apple iTunes
The program doesnt open as it says the folder iTunes cannot be found....it also says the default location of the driver is in folder Music, i created a folder called Music and it still wont open...y?
  • 32 Answers
Just uninstall the itunes and then install it again. if you cant find the folder then just go the apple website and install it again.
Posted on Jun 22, 2009
ITunes stopped working.
Search for a folder called iTunes Library - if you find it, click directly on the file inside this folder called iTunes Library.
If you find more than one, select the one you prefer and later you should be able to delete the others ..
If you open iTunes by clicking on the library, instead of just opening iTunes, it should set the library for you in the iTunes Preferences and it "should" stay that way ... just to be sure, close iTunes and then reopen the normal way, just by clicking on the program ... see what happens ...
Be careful not to delete any "extra" libraries that contain music that is not in the library you select - ideally you should have only one library with all the music, videos, etc, in it ...
If this doesn't work, go to Preferences in iTunes and look at the "advanced" tab - look at what it says for iTunes media folder location - make sure this is where your library is ...
This process can be a bit complicated, particularly if you have more than one library, so it's important to find the one library you want to keep, make sure all the music and other things are in it (copy everything in if you have to) and delete any additional libraries ...
Let us know what happens, how it works out. If you have more questions come back!
Once you get it set correctly, don't move your iTunes library if you don't have to, because it is a little confusing to get iTunes to show all your music correctly again ... if you have to, search on Google for "how to move iTunes Library" for help before you do it!
For help with Sound System Feedback, rexark.com
Mar 02, 2010 | Apple iTunes
Tip
The ITunesLibrary.itl cannot be read because it was created by a newer version...
1. Quit iTunes.
2. Locate your iTunes folder.
Operating System Default location of iTunes Folder
Microsoft Windows XP and 2000 Documents and Settings[your username]My DocumentsMy Music
Microsoft Windows Vista Users[your username]Music
Microsoft Windows 7 Users[your username]My Music
3. Open your iTunes folder.
4. Drag the iTunes Music Library.xml to the Desktop
5. Drag the following file from your iTunes folder to the Trash:
Microsoft Windows "iTunes Library.itl" (in versions of iTunes prior to 4.9 this was called "iTunes 4 Music Library.itl")
6. Open iTunes.
Important: Do not add any content into iTunes at this point.
7. Choose File > Library > Import Playlist.
8. Navigate to the iTunes Music Library.xml file on the Desktop.
Windows users: Click Open.
on Apr 25, 2010 | Computers & Internet
Can't open itunes
You need to reinstall Itunes and point it towards the correct drive/folder again. When you attached the second hard drive it would have fouled the pointers in iTunes.
May 25, 2009 | Apple iTunes
I have a classic iPod 80Gb. I have just loaded iTunes v8.1 onto my laptop using Vista home. When I try to ope iTunes the following message comes up:"The folder iTunes cannot be found or created and is...
Uninstall the egzisting itunes by following steps. Start menu> Control panel>click on the Control Panel home on the upper left side>same windows you will see the programs and under Unisnstal a program waith for list of programs refreshes highlight Itunes and press the Uninstall tab and reinstall the Itunes
May 01, 2009 | Apple iPod MA446LL/A MP3 Player
Can't get itunes to work
The error message “The folder iTunes cannot be found or created”. It was referring to the My Music directory that is usually located in the My Documents folder on the partition containing the operating system. The iTunes software creates an iTunes folder in the My Music directory on first start and if that directory is not accessible it will throw the error message and fail to load.
Since this error is related to the My Music folder it is important to check the directory path of that folder in the Windows Registry. This is best done by using the shortcut [Windows R], typing [regedit] and hitting the [enter] key.
The fastest way of location the two locations that contain path information for the My Music folder is to use the search by pressing [F3] and entering [My Music] in the search box. A click on [Find Next] will start the search and reveal the two locations.
The test computer system did not have path information listed at all. This can be changed by double-clicking the My Music key in the Registry and changing the path to an valid path manually.
The two Registry locations that list the My Music path are the following two:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
Make sure both point to a valid path on the system. Once the path has been changed iTunes will create the iTunes folder in that location and start up without this error message.
Please back up your registry before doing this. messing in the registry can make your computer stop functioning.
Make sure you follow the correct registry entry.
Apr 26, 2009 | Apple iTunes
I combined 2 partitions into one partition using Partition Magic
In iTunes under preferences, you can go to the Advanced tab and specify the new location where you moved the folder to. By default it puts it under My Documents/My Music/iTunes Music. If you've messed with what drive that's on you need to change it in iTunes so it knows where it is.
Mar 24, 2009 | Apple Audio Players & Recorders
I Tunes will not open . I get the message - The folder "I Tunes"  cannot be found and is required. The default location for this folder is inside "My Music" folder. I have checked and the I tunes...
hello there!!
thanks for using Fixya.com!!!
Try to uninstall the program first, just go to the control panel and select add/remove programs then select the I-tunes program. then try to install again the software, but make sure that you do it as recommended.
hope this will help you!
you may download the program on this site.
apple.com/itunes/download
Good luck!!
Feb 16, 2009 | Apple iTunes
ITunes won't open
Go to "Preferences" in iTunes and change the music folder location to the location on your new disk drive. Click the boxes as shown below:
image.tiff
Dec 28, 2008 | Apple iPhone Smartphone
Disk is Locked Error
If the My Music folder is in the wrong location or incorrectly assigned in the Windows registry, you may see one of the following error messages:
  • "The folder iTunes is on a locked disk or you do not have write permissions for this folder."
  • "The folder iTunes cannot be found or created and is required. The default location for this folder is inside the Music folder."
If you see one of the above errors, follow these steps to troubleshoot this:
  1. Verify the location of your Windows XP My Music folder. The default location for this folder is
    C:\Documents and Settings\username\My Documents\My Music
    If you do not have this folder at the default location and have not moved it to another location, consider creating one inside your My Documents folder.
  2. Download and install Tweak UI from the Microsoft PowerToys website at http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx Note: This utility is for Windows XP only. Please review the system requirements before installing.
  3. Once you have installed Tweak UI, open it from the Start menu.
  4. In the column on the left, click on the plus symbol (+) next to My Computer and select Special Folders. ht1866_01.jpg
  5. In the right pane on the Folderlist, click My Music.
  6. Click the Change Location button. You may see a warning message appear with precautions for changing this setting; after reviewing the message, click Yes. ht1866_02.jpg
  7. In the resulting window, browse for the My Music folder as described in step 1, and click OK. ht1866_03.jpg
  8. Reinstall or open iTunes.
Oct 13, 2008 | Apple iTunes
ITouch & iTunes
Firstly you will need to create a folder in 'My Music' and Rename it iTunes.
Write Back And i Wll Tell You The next stage.
Feb 20, 2008 | Apple iPod touch
Apple iTunes Logo
87 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
