Question about Garden
Kubota strimmer which fuel should i use?
I need a wiring diagram for the fuel shut off solenoid for a kubota m6800
Contact Kubota directly to request the wiring diagram.
Jun 07, 2017 | Kubota Garden
Digram of fuel system for kubota L2250DT
Sorry we do not have any information on this.
Mar 28, 2017 | Kubota Garden
M108x kubota will not crank, checked all fuel lines fuses on top of engine 1800 rpm tractor starts to miss
if it will not crank , it will not start
if you get it running and it misses , that is injector or fuel flow problems
Mar 27, 2017 | Kubota Garden
My m105s kubota tractor wont start -fuel prolems
Glowplug may bbad or the fuel injectionpump. Chec utube ir git a shopmanual
Dec 27, 2015 | Kubota Garden
Kubota 900 rtv fuel system
two thing to know, if you have been below freezing for some time and haven't treated fuel it might be gelled, my first guess, also could be a plug or gelled fuel filter as well... another guess would be the fuel pump
Mar 13, 2014 | Garden
Kubota D430XL strimmer how do you change bearings in head
Hi Steve,
It has been a long time since you have posted this question...have you been able to solve the problem? i came accross your post as I have/had the same problem today, but managed to solve it quite cheap.
I will be more than happy to help if the problem persists.
Regards,
Pieter
Jun 05, 2012 | Garden
Fuel mix for ALKO RT250 strimmer
Mix one ounce of 2 cycle oil per quart or 4 ounces of oil per gallon of unleaded gasoline. Hope this helps and best wishes.
Aug 28, 2009 | McCulloch Lawn Care: Trimmer Plus...
2 stroke mixture ratio for strimmer
The basic fuel/oil mix is 50 to 1
May 04, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
