Question about Canon Computers & Internet
E00051 0000 trun the main powar swich (on the main units right side ) OFF & ON agin lf the machine htill does not opert normaliy connect your servise rep- resempative with the ERROR CODE BELOW EEEOR CODE E000051-0000
  • 5 Answers
SOURCE: error code E000051-000
E000051-000 is not a waste toner full error code thats E000015. This error code refers to the horizontal registration sensor not reaching home position or is not detected when the assembly is commanded to move. The sensors function is to determine the edge of the sheet of paper in the front to rear direction to determine the write position on the drum. It is not somthing you can fix and would require a tech. Possible sources of the error are, DC controller, horizontal registration sensor or actuator, or the horizontal registration motor. Based on experiance the motor is either stuck or burned out so the sensor does not move at start up
Posted on Jun 07, 2008
SOURCE: e000004-0010
canon NP 6330
error 800
Posted on Jul 24, 2008
frcs68
  • 1605 Answers
SOURCE: "981 Service Switch Error" and "994 Servise Density Sensor"
these are internal error. beyond user capability or repair
turn off the printer and check all of the cable connections.
turn on the printer, you need to call lexmark service, if the error returns.
Posted on Nov 11, 2008
  • 199 Answers
SOURCE: what is that eror code E000051-0000
E051-0000
At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
because The horizontal home position sensor is faulty or the horizontal registration motor is faulty.
Posted on Feb 26, 2009
  • 89 Answers
SOURCE: Cannon Imagerunner 2200 Error COde: E000051-0000
There is information in the Service Manual to fix this problem. Make a service call and get a technician to fix this problem.
E051 is Horizontal registration HP detection error
0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main cause: The horizontal home position sensor is faulty. The horizontal registration
motor is faulty. The DC controller PCB is faulty.
This problem should be handled by a technician.
Posted on Jul 30, 2009
How to splice a sub-woofer to speakers
Normally the sub woofer is driven by a separate amplifier, unless the main speakers, such as in a pro audio setup have a special LF out set of terminals on the back of the speaker cabinet, in this case there is a hi powered low pass filter, fitted in side the speaker to route the LF energy to a sub woofer. Else you need a line lever LF signal spliter and a power amplifier to connect a sub woofer.
Jan 26, 2017 | Audio Players & Recorders
Maytag 2000 Error LF what does this mean
The LF error code indicates a long fill condition.
What you need to do is check the filter screens where the hoses connect to the unit. Remove the hoses at the back of the unit. The screens are hust inside of the connections. Make sure they are free from any debris.
or
https://www.youtube.com/watch?v=1M-XgRT3obc
or
http://ths.gardenweb.com/discussions/2441868/maytag-bravos-lf-error-code-solved
Apr 29, 2016 | Maytag Washing Machines
On/off button not working
k9 on off problam..........plz help me
Jun 06, 2012 | Karbonn K9
Cam senor
this is possibly a loose eleectrical connection at starter battery or alternator check tightness clean connections
Nov 10, 2011 | 1997 Mercury Sable
The washer is not finishing cycle shows the code LF
LF = Long Fill
Is water supply connection turned on.
Are hose screens plugged? ( these are inside the inlet on the machine where the hoses connect )
Is water entering the tub? If so, check the pressure hose connection to the machine/motor control. This is the main control unit. There is a service manual inside the machine. If you open the top of the unit with a screw driver in the front, the manual should be on the inside of the front panel.
Aug 17, 2011 | Kenmore Washing Machines
Electric windows and mirrors not working-not a fuse
There is a posibility that the connections may have been block or the connection to them is broken ... this also happens while servecing car the water get is the main system but happens real rear ... so you can go to work shop and ask electrition for check ..
May 31, 2009 | 1995 Land Rover Range Rover
Display issues on CDX-FW570
YOU MUST RESET THE PLAYER BY PRESSING A RESET SWICH LOCATED ON FRONT SIDE OF YOUR PLAYER. PRESS THE RESET SWICH FOR 10 SECONDS WHEN THE POWER SUPPLY IS ON.
IT MAY SOLVE YOUR PROB.
BEST LUCK
REGARDS
KETAN PATEL
Feb 11, 2009 | Sony CDX-FW570 CD Player
Oasis elite top load washer
LF code LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display
You will need to check you fill hoses this is 95% of the problem in the rear of the unit ther are two hoses Hot and Cold feeds shut off the water and Unplug the unit Then remove the hoses from the machine. in the Valve where the hoses go to there are little mesh screens they are most likely clogged take a eyeglass screwdriver or paper clip and hook the screens pull them out carefully and clean them reinstall and connect hose and test
Dec 19, 2007 | Kenmore 24032\24036 Top Load Washer
Lf what does it mean?
Lf means long fill make sure your taps are on. or your filters in the hoses arn,t plugged in other words it is taking longer than 10 minutes to fill
Dec 11, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Computers & Internet Logo
37 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
