Question about Philips VOIP8411B/37 IP Phone
I need vpn with my lenovo tablet 2 - Philips VOIP8411B/37 IP Phone
Tip
How to unblock sites in iPad or iPhone
The most secure and reliable way to open blocked sites in iPad or iPhone is using vpn. You do not need any specific application for this. You can simple make a new vpn connection on your iOS device with standard iOS features.
All you need is setup vpn connection following simple steps below:
To make a new vpn connection in your iOS device you need to do the next:
  1. Go to Settings > General > VPN
  2. Click Add VPN Configuration
  3. Choose PPTP VPN and enter you VPN account data. You will receive your VPN server, username and password in the e-mail
    Server address must be exactly as in your account data (without http://, www or any other symbols)
  4. Save your VPN configuration. Once you have created VPN connection you can switch it ON and OFF on the main settings screen
Once you have created vpn connection you can switch it on and off on the main settings screen.
Under the vpn connection you can access any blocked website and be absolutely sure that you are safe and secure.
Sahrzad VPN How to Setup Guides
on Sep 14, 2015 | Apple iPad Tablets & eReaders
I use a Lenovo TB2-X30L. I connect to my WiFi, but it switches off after 1 second. What is the problem
If you are not seeing the 3g modem in Device Manager (Start > Run devmgmt.msc and press Enter, or access via control panel) try installing the driver for your systems 3G modem , which I believe is available in the link below, but enter the serial # etc. on the page just to be sure you get the right one. If the modem is showing as an "Unknown Device" or has a Yellow Exclamation Point displayed to indicate it as a non-working device in the Windows Device Manger, try right clicking on it, select uninstall, and check the box to delete existing driver software and reboot. Once rebooted, it should re-detect the modem and install the needed drivers automatically.
Note that from Device Manager, you can from the View Menu select "Show Hidden Devices" and see devices not normally displayed., so see if anything shows up there too.
ThinkPad Tablet 2 Drivers (look under Networking Wireless WAN)
http://support.lenovo.com/us/en/products/tablets/thinkpad-tablet-series/thinkpad-tablet-2?tabName=Do...
If the device is working, but you are having trouble with it recognizing the SIM Card, you might read through this older thread and see if that helps.
Tablet 2 Lenovo Mobile Access -> SIM CARD?
https://forums.lenovo.com/t5/ThinkPad-Tablets/Tablet-2-Lenovo-Mobile-Access-gt-SIM-CARD-3679-25G-N3S...
Good Luck.
Aug 29, 2017 | Lenovo Computers & Internet
Daughter put password on her tablet and now it does not want to work - how do I override the password or get access to the tablet
http://www.hardreset.info/devices/lenovo/lenovo-tab-2-a7-10/
the above link is to 3 different hard reset procedures. One should work on your tablet. You will lose all of the data on your tablet.
Aug 19, 2016 | Lenovo Tablets & eReaders
My tab stucked during start and its freeze in lenovo logo
Android Tablet stuck on boot screen ! Bypass it in easy steps ...
? 4:36
https://www.youtube.com/watch?v=HErn0-GcQqE
Jan 4, 2014 - Uploaded by My Tablet Guru
If your Android tablet is stuck on startup or boot screen, then bypass it ... 1) Press the volume up or volume down or home button when the tablet start, .... is support on my tab . its also stoc on android logo plz bro help me . .... How to fix most tablets if they freeze - Duration: 2:21. by JunkyBlake 236,241 views.
Lenovo Yoga 8 Tablet stuck on boot screen - Lenovo Community
forums.lenovo.com > ... > Lenovo Tablets > Android Yoga Series Tablets
Apr 21, 2014 - I have the exact same problem with a yoga 10, it is stuck on the lenovo... Yoga 8 was working fine last night but today it's stuck on boot up with ... lenovo tablet a3300 gv stuck on lenovo logo
May 17, 2015
Stuck in Lenovo Screen - G500
Apr 6, 2014
Lenovo IdeaPad A1000 stuck on recovery mod
Dec 23, 2013
ThinkPad hangs on boot - stuck at Thinkpad screen
Feb 2, 2012
More results from forums.lenovo.com
Dec 21, 2015 | Lenovo Computers & Internet
How do I delete vpn from my apple ipad air 2?
Do what you have done but when you go to VPN Configuration you should see a Blue i in a circle tap in on that icon. You should then see the settings for the VPN, at the bottom you will see Delete VPN click on that.
Feb 11, 2015 | Apple - iPad Air 2 Wi-Fi 64GB
What is turned off on my keyboard to cause my Lenovo Idea Pad P500 with 8.1 to stop working when I wy-fi out on VPN to a remote site, while my Dell works fine.
you have to have your wirless going or a conecion first to internet for a VPN to work,,, start with your internet conection then your wireless connection. if they are fine and you still can't connect 1. vpn softare is corrupt. 2. setting in vpn on your laptop got changed 3. turn your caps off , for singing into vpn 4. unlock your keyboard number pad there really isn't much ona keyboard.
May 14, 2014 | Lenovo Computers & Internet
How do you turn off the lenovo thinkpad tablet 2 keyboard?
You turn the power off to the Thinkpad Tablet 2 keyboard by holding the power switch to the right for 3 seconds.
Mar 05, 2013 | Lenovo ThinkPad Tablet 2 Bluetooth...
Philips VOIP8411B/37 IP Phone Logo
32 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
