Question about Dell SE198WFP LCD Monitor
When plugged into power I get no green light at the pwr switch, All is black. Is there a fuse burned out or is the pwr. switch broken???
    Problem Solver:
  • 9 Answers
1. Try a different power cable.
2. Open the monitor up, see that the soldering to the cable connect, or the switch isn't broken.
Posted on Oct 01, 2009
07 chevy suburnan wiring diagram color
Item12 VoltsSecond 12 VoltsStarterSecond StarterIgnitionSecond IgnitionThird IgnitionAccessorySecond AccessoryThird AccessoryKeysenseData BusCan Bus HighCan Bus LowCan Bus SwPower LockPower UnlockLock MotorDriver Unlock MotorPassenger Unlock MotorParking Lights (-)Parking Lights (+)HazardsTurn Signal (Left)Turn Signal (Right)HeadlightAutoLightsReverse LightLeft Front Door TriggerRight Front Door TriggerLeft Rear Door TriggerRight Rear Door TriggerDome SupervisionTrunk/Hatch PinRear Glass PinHood PinTrunk/Hatch ReleaseTrunk Release MotorFuel Door ReleasePower Sliding Door (Left)Power Sliding Door (Right)Factory Alarm ArmFactory Alarm DisarmDisarm No UnlockTrunk Alarm ShuntTachometerWait to StartNeutral SafetyClutch PedalFuel PumpRear DefrosterMirror DefrosterLeft Front Heated SeatRight Front Heated SeatSpeed SenseBrake WireParking BrakeHorn TriggerWipersLeft Front Window (Up/Down)Right Front Window (Up/Down)Left Rear Window (Up/Down)Right Rear Window (Up/Down)Sun Roof (Open/Close)Sun Roof (Limit/Close)Memory Seat 1Memory Seat 2Memory Seat 3Radio 12VRadio GroundRadio IgnitionRadio IlluminationFactory Amp Turn-onPower AntennaLeft Front Speaker (+/-)Right Front Speaker (+/-)Left Rear Speaker (+/-)Right Rear Speaker (+/-)Center Channel (+/-)Subwoofer (+/-)Aux. Audio Input Left (+/-)Aux. Audio Input Right (+/-)RSE Video (+/-)RSE Audio Left (+/-)RSE Audio Right (+/-)Satellite Radio 12 VoltsSatellite Radio GroundSatellite Radio IgnitionSatellite Radio AntennaSatellite Audio Left (+/-)Satellite Audio Right (+/-)HeadunitLeft Front SpeakerLeft Front TweeterRight Front SpeakerRight Front TweeterLeft Rear SpeakerLeft Rear TweeterRight Rear SpeakerRight Rear TweeterCenter ChannelSubwooferLeft Front HeadrestRight Front HeadrestLeft Rear HeadrestRight Rear HeadrestSatellite Radio Tunerspacer.gifspacer.gifWire Colorred/black (60A), red/black (60A)red/white (x4) (15A each)purple (for starter kill only)pink/black (resistor code), white (5V reference)pinkN/AN/Abrown or yellowsame as second starterN/Asame as second starterdk. green (low speed GMLAN)tan/black (high speed GMLAN)tan (high speed GMLAN)dk. green (low speed GMLAN)use Directed interface modulesee power lockgraypurpletanlt. bluebrown (L), brown (R)whitelt. blue/white (F); yellow or yellow/black (R)dk. blue/white (F); dk. green or dk. green/wht (R)whitedk. green (ground to turn off autolights)dk. bluegray/black (ajar), tan (open)black/white or tan/whitelt. blue/blacklt. green/blackgraypink/blacksame as trunk/hatch pinpink/blackgray (liftgate), pink (liftglass) (rear handle sw)lt. blue (liftgate)N/AN/AN/Aarms on lock with door openlt. green (driver door key cylinder)Passkey and ignitionN/ANOT pinkN/AN/AN/Adk. green/whitepurpleorange or black (L), orange or black (R)dk. blue (back and cushion)dk. blue (back and cushion)dk. green/white (some models only)lt. blue/white (functions with ignition on only)lt. bluetangraydk. blue - browndk. blue - browndk. blue - browndk. blue - brownbrown - org or lt. blu (function with ign on only)N/Aorangesame as memory seat 1N/Ared/whiteblack(low speed GMLAN)yellow (dimmer)same as power antenna (some models only)whitetan - gray or tan - dk. greenlt. green - dk. green or lt. green/white - org/blkbrown - yellow or brown/white - browndk. blue - lt. blue or dk. blue - tandk. blue - orange (with surround)white - pink (with surround)yellow - (bare wire)white - (bare wire)dk. green - white/blacklt. blue - purplewhite - purplered/whiteblack(low speed GMLAN)(coaxial cable)brown/white - tan/whitedk. green/white - graydouble DIN6.56.55.255.25spacer.gifspacer.gifPolarity++++9.6K ohms+++6.3K ohmsdatadatadatadata5 wire5 wire5 wire-+-++--+----+---+-ac+reverse+ latched--ac+--+AAAA-+2.26Kohms+4.26Kohms+-+++,-+,-+,-+,-+,-+,-+,-+,-+,-+,-+,-+-+,-+,-spacer.gifspacer.gifWire Locationdash fuse box, black 40 pin plug (X1), pins F1 and E3BCM, black plug, pins 1, 2, 3, and 4starter or underhood fuse box, blk 50 pin plug (X2), pin F1 or F5ignition switch or BCM, lt. green plug, pins 2 and 4ignition switch or BCM, lt. green plug, pin 14ignition switch or BCM, lt. green plug, pin 21PASS-Key III+ Module, black 5 pin plug, pin 4data link connector, black 16 pin plug, pin 6data link connector, black 16 pin plug, pin 14data link conn, black 16 pin plug, pin 1 or BCM, lt. blue plug, pin 10driver kick or dash fuse box, black 14 pin plug (X3), pin B4driver window switch, brown 16 pin plug, pin 8driver kick or dash fuse box, black 14 pin plug (X3), pin B1headlight switch or BCM, white plug, pin 8underhood fuse box, black 30 pin plug (X3), pins A7 and F7hazard switch or BCM, lt. green plug, pin 19BCM, brown plug, pins 4 and 1BCM, black plug, pin 5; brown plug, pin 2headlight switch or BCM, white plug, pin 12headlight switch or BCM, white plug, pin 17BCM, white plug, pin 22driver window switch, brown 16 pin plug, pins 13 and 11passenger window switch, brown 16 pin plug, pin 13BCM, pink plug, pin 15BCM, pink plug, pin 14BCM, white plug, pin 5BCM, pink plug, pin 12hood switch or BCM, black plug, pin 17BCM, pink plug, pins 13 and 24passenger kick, harness to reardriver window switch, brown 16 pin plug, pin 4any fuel injectorECM, black 73 pin plug (X1), pin 50driver kick, harness to reardriver and passenger window switch, black 10 pin plug, pin 7driver window switch, gray 14 pin plug, pin 6passenger window switch, gray 14 pin plug, pin 6EBCM, blk 38 pin plug, pin 11 or 32 or radio, brn 16 pin plug, pin 5brake switch or BCM, brown plug, pin 6parking brake switch or BCM, brown plug, pin 16horn switch or BCM, brown plug, pin 18BCM, brown plug, pin 20driver window switch, black 6 pin plug, pins 3 and 1passenger window switch, black 6 pin plug, pins 3 and 1left rear window switch, black 8 pin plug, pins E and Hright rear window switch, black 8 pin plug, pins E and Hsunroof switch, black 8 pin plug, pins 6 and 4driver window switch, gray 14 pin plug, pin 5radio, black 14 pin plug, pin 1radio, black 14 pin plug, pin 8radio, black 14 pin plug, pin 7radio, black 14 pin plug, pin 6radio, black 14 pin plug, pins 2 and 9radio, black 14 pin plug, pins 3 and 10radio, black 16 pin plug, pins 5 and 13radio, black 16 pin plug, pins 6 and 14radio, brown 16 pin plug, pins 3 and 11radio, brown 16 pin plug, pins 4 and 12radio, gray 16 pin plug, pins 1 and 9radio, gray 16 pin plug, pins 2 and 9radio, gray 16 pin plug, pins 7 and 15radio, gray 16 pin plug, pins 3 and 11radio, gray 16 pin plug, pins 4 and 11Digital Radio Receiver, black 16 pin plug, pin 16Digital Radio Receiver, black 16 pin plug, pin 9Digital Radio Receiver, blk 16 pin plug, pins 2, 1Digital Radio Receiver, blk 16 pin plug, pins 3, 4center of dashleft front doorleft front pillarright front doorright front pillarleft rear doorleft rear pillarright rear doorright rear pillartop center of dashunder front of center consoleunder passenger dash, behind glove boxspacer.gifspacer.gifPhotohas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifspacer.gifspacer.gifNotehas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifspacer.gif
Nov 03, 2012 | Cars & Trucks
Tip
LCD TV TROUBLE SHOOTING
1.Do not power on .
1 .1 Please check AC cable if connect to AC plug. Is true the connector don't connect to AC plug. Please connect it.
2.2 Please check AC cable if connect to AC power. Is true the AC cable don't connect to AC power. Please connect it.
3.3 Please check power board of fuse if broken. If the F1 fuse is broken, Please pull out the AC cable from AC power. Please check AC L power and AC N ground by multimeter, The read number is infinite, the fuse is broke. Then look up power board if not burn out place. Is true it. Please change power board or be changed power board.
2. The power on switch of green extinguish.
2.1 The power of led(indicator light) is red light, To touch power on key when indicator light wink. Is true that the power DC output have somewhere short circuit. Check connector J39,J31 .If not connector direction is wrong. Or the mainboard somewhere of power short circuit.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
on Feb 14, 2015 | iLO Televison & Video
I have an MS-7502VER:1.2 motherboard and i cannot find wher to plug the power switch into
Hi scouts692
The Front Panel Header Pin arrangement for this motherboard is unusual, in that the header only appears to have 8 pins in a single column rather 2 parallel columns of 6 Pins with 1 blank, as most conventional motherboards do.
Pin 1 is POWER SWITCH orange or red (PWR SW 1)
Pin 2 is POWER SWITCH white or black (PWR SW 2)
Pin 3 is POWER LAD + (PWR LED -)
Pin 4 is POWER LED - (PWR LED +)
Pin 5 is HARD DRIVE LED - (HD LED -)
Pin 6 is HARD DRIVE LED + (HD LED +)
Pin 7 is RESET SWITCH blue or green (RST SW/RST 1)
Pin 8 is RESET SWITCH white or black (RST SW/RST 2)
Please refer to a PDF of the Motherboard Manual for additional information about the setup of this motherboard (the relevant page for the Front Panel Header is page 17/Section 2-13)
hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 17, 2011 | Intel Motherboard
What colors are the wires for the pwr sw, smi,rst,hdd led,grn led and where so i plug them in at s7sen 15-a01-013010 rev 3.0a
- the colors of the wires (can differ, depends on the case type):
  • Green(+ is the colored wire)-White(-) --> POWER LED (GREEN light)
  • Red-Black -> POWER SWITCH
  • Red-White -> HDD LED (RED light)
  • Blue-White -> RESET
  • Red-Black (4 pins wide)-> SPEAKER
Sep 03, 2010 | EliteGroup K7SEM Motherboard
Doesn't turn on after smoke comming from pwr switch
Hi
More than likly you thermal fuse is burnt out( top left side of the boiler under the small clamp). But something caused it to smoke and melt, like the element shorted.
Jun 04, 2010 | Saeco Classico Espresso Machine
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Jul 28, 2009 | Computers & Internet
System wont power on unless mb power connector on mb is reset
by mb pwr connector do you mean the swich on the pc case that you press to turn it on or do you mean the large block connector form the power supply ?
If you mean the case switch then you have a faulty one that is sendinga constant signal and locking up the power supply
Jul 17, 2009 | HP Media Center m7060n PC Desktop
No brake lights
The two wires running the length of the truck are most likely a 12volt pwr supply,a ground or trailer brake signal wire.usually for charging a camper trailer battery and trailer brakes, check the brake lamp fuses in your fuse centre,most likely 10a.replace if open.if they still are inop,check with a test lamp to see if pwr is at the light sockets,(clamp of test light to good ground,usually white wire for brake)if no pwr is there then make your way to where the trailer plug was installed and check for pwr there(make sure your brake peddle is depressed during these tests,with key off as not to pwr up the park lamps)also check the ground at the same time(usually black)by reversing your test lamp(clamp to 12v)your brake switch could also be faulty(switch with button on arm of brake peddle).pick up a chiltons or haynes service manual to help with wiring diagrams and wire colors.
Apr 04, 2009 | 1991 Chevrolet C1500
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
Dell SE198WFP LCD Monitor Logo
121 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
