Question about Samsung SyncMaster P2270 22 inch Monitor
Where can I buy Power Supply for Samsung SyncMaster p2270?
4 Suggested Answers
  • 17 Answers
SOURCE: how much is the power supply of samsung syncmaster
normally, it cost $20~$39 with shipping.
Posted on Mar 22, 2010
technical114
  • 1851 Answers
SOURCE: I am running Windows XP Professional operating
Your monitor's native resolution is 1920 x 1080, as you can see for the official specifications. This means that the best off the quality and the clearest screen will be when you set the screen resolution for the windows XP at 1920X1080 (right click on an empty area on your screen - click on properties - click on the settings tab - set the resolution slider at 1920X1080 - hit apply - accept the change - hit ok) In case you can't the resolution rate at this setting, sorry to said but your VGA subsystem is not capable to give the right signal at the monitor, so you have to think of an update. In case your desktop's icons are too small you can change the size with this simple tip: right click on an empty area on your screen - click on properties - click on the appearance tab - at the lower of the window change the font size to large or very large - hit apply - hit ok.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Feb 02, 2011
budmrtn
  • 11361 Answers
SOURCE: How do I open a samsung syncmaster 920nw to get to
You lift up the front bezel, just go around the bezel but do not completely remove it, just on three side, then lay it face down and snap up the back cover. Be real careful with the cable attached to the front bezel.
http://s807.photobucket.com/albums/yy352/budm/Samsung%20920NW/http://s807.photobucket.com/albums/yy352/budm/Samsung%20920NW/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 27, 2011
On my syncmasterp2270 I plug in that white power cord thing into the hard drive and it still won't turn on. I saw it up and running in the shop yesterday so I know I'm defs doin something wrong?
You have to plug in two cords. One you plug into the power outlet/power bar and the other you plug into your computer.
You might also have to actually press the power button on the monitor to get it to turn on. Some power on right away when you plug them in, others do not!
Jan 21, 2014 | Samsung SyncMaster P2270 22 inch Monitor
Hi, my syncmaster p2270 seems to have some kind of focus issue. Everything is sharp, but to the right of the visuals on screen there is a duplicate, reflection of whatever is being displated on screen....
Hi Jonhy, on the pc , try this steps:
1. At the mainscreen mouse rigth click and go to Properties
2. Go to Definitions and Advanced
3. A window with graphic board's properties will come up and the choose 3D setup/config (depending on graphic board mark)
4. Change from Direct 3D to OpenGL and then Apply and OK to close.
This procedure is to change from hardware aceleration to software aceleration of image on screen. As that it will be sent only one kind of image definition from the pc to the screen with no repeating or mirrowed data. Hope it will helps you.
Nov 04, 2013 | Samsung SyncMaster P2270 22 inch Monitor
Problem with sansung syncmaster 931b off/on switch. I have to turn it off/on about 12 to 20 times before it stays on. Thanks Bob.
Your power supply board is not yet dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help
Dec 02, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Monitor is loseing its picture.
Open up your monitor and open your power supply. Check for any bad capacitors. And replace them with the same or bigger number. If everything inside the power supply looks good then its probably the back light going bad.. Its probably best to buy a new one in that case.,.
Apr 02, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
How much is the power supply of samsung syncmaster 940nw
It depends, you need to open it up abd get the number as printed on the board since it may have more than one version or maker of the power supply/inverter board. The problem can be as simple as failed capacitors, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
I estimate the bd to be from $60 and up if you can get used one from EBAY, but I will not buy it unless the board is recapped.
Mar 22, 2010 | Samsung SyncMaster 920NW Monitor
Hi My Syncmaster 940MW LCD,is cutting out and switching itself off after 10mins or so. Also some times it takes a few presses of the on/off switch to turn it on at all?Can anyone advise please
Power supply board is dead.Replaced the power supply board should solved this problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for replacement.
Feb 12, 2010 | Samsung SyncMaster 940MW 19 in. LCD...
My Samsung SyncMaster 226CW flickered and then shut off...it will not turn on anymore. anything i can do here to avoid buying another.
yes reove rear cover. look at power supply for crowned or leaking capacitors. desolder . take bad ones to electronics parts store, replace and good to go
Dec 26, 2009 | Samsung SyncMaster 226CW 22" Monitor
Need to get a new power supply for my samsung monitor
you first look the watt on the power supply and if same watt power supply is available then connect because power supply has overload protection it will not work also look the connecter is matching if not then purchase only original power supply dont chase the duplicate it will consume more money
Nov 20, 2008 | Computers & Internet
Samsung SyncMaster P2270 22 inch Monitor Logo
21 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
