Question about Fargo HDP5000 Thermal Printer
Fargo HDP 5000 heater error 161
My printer keeps bringing the fault 161 heater error please help me solve this problem
2 Suggested Answers
SOURCE: we just bought Fargo HDP5000.
hola hermano tengo problema con mi impresora hdp 5000 cada vez que boy a imprimil me da un error 103 y 105 me dice en la pantalla del monitor de mi pc que el sensor no detecta el movimiento del cabezal
Posted on Aug 26, 2011
My fargo printer 5000 says no supportted printer detected on this system
It sounds like it is your computer operating system telling you do not have the appropriate driver installed.
See if these links help!
Fargo HDP5000 Driver
Fargo HDP5000Supported Features
Drivers Downloads
https://www.hidglobal.com/drivers/14761
May 30, 2016 | Fargo Office Equipment & Supplies
I have a Fargo HDP 600 printer, when I turn it on it states, "Loading printer settings now, please wait... and it stays like that. Is there any way to reset this printer? Now its not recognizing the usb
Physically disconnecting the printer from its power source, then reconnecting will force a hard re-boot of the printer itself. If this fails, try updating the device drivers & firmware (download directly from the HID Global website here: Drivers Downloads ).
If you get no relief here, it may require service. BUT, as this printer is an older model and out of support, your best option may be a replacement unit.
Jan 05, 2015 | Fargo HDP600 Thermal Printer
Why my Fargo ProL is not printing Edge to edge?
it depends how much edge to edge you want, its a direct to card printer and will not print all the way to the edge 100%. you can get it close by adjusting the horizonal settings, but to get true edge to edge you need the HDP printers.
Jul 18, 2014 | Fargo Pro L ID Thermal Printer
Fargo HDP 5000 heater error 161 fault
This error usual occurs after a large print job (50 prints in a row). Try shutting off the printer, and leaving it off for a good 15 minutes. Turn back on and retry.
If the problem persists, then you should contact a service center. It seems to have a failure in an internal sensor.
May 06, 2014 | Fargo HDP5000 Thermal Printer
Image color adjustment hdp 5000
on the printer property dialog select image color tab then advanced settings, for darker images increase sharpness and contrast and decrease gamma to you satisfaction
Aug 26, 2013 | Fargo HDP5000 Thermal Printer
Error 103 headlift error fargo hdp 5000
erro 103 could cos by head voltage erro or head fit erro.
this could be a problem with the printhead lift or transfer roller headfit.
reset the printer and try again ...
Jan 05, 2013 | Fargo HDP5000 Thermal Printer
My printer show the error 99 Ribbon Break/Jam but the ribbon is ok is not broken and i can not see some jam. Can you help me
Pls do the following:-
Ribbon Break/Jam
(PC Error Message No. 99, 108 and 109)
The Ribbon is not able to find the next panel correctly. Check for jams/breaks.
If jammed, clear the jam. If broken, repair by taping the Ribbon back on to the take-up core.
Press Resume to continue or Cancel to abort.
Thank You...........
Jul 26, 2011 | Fargo HDP5000 Thermal Printer
We just bought Fargo HDP5000. on first installation now its bringing error code 97 and 99 which when we calibrated the printer the error 99 was solved. but the error 97 is still there. pls help
Apr 19, 2011 | Fargo HDP5000 Thermal Printer
Hello can you really help me solve the error code that i getting on my IR 5000 the code is E000012-0000
That error means that you have a problem with the drum motor. Check the it's connectors. Or maybe something keeping the motor from running, like an uptwisted blade with drum.
Dec 25, 2008 | Canon imageRUNNER 5000 Copier
FRAGO DTC550 ID MACHINE
The is usually resolved by replacing the head lift motor or sensor.
Dec 17, 2007 | Fargo DTC550 Thermal Card Printer
Fargo HDP5000 Thermal Printer Logo
121 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
pkwc
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
