It is a new dell computer but the projector seems to be a little older. Im teaching a class soon and need it to work! any suggestions?
SOURCE: Proxima Ultralight Projector 350x
The filters probably need cleaning. Also check and make sure none of the vents are being blocked.
SOURCE: drivers available
You can download all the information you need from:
http://www.askproxima.com/service/m3/m3.asp
Jason
LCMA Insurance
http://www.lcmainsurance.com
SOURCE: InFocus Proxima UltraLight LS1 LCD Projector
There could be several reasons for this problem.
1. New lamp needed.
2. New lamp did not fix? Could be mirror tunnel behind the color wheel than can collapse causing "dim" light source or dark lines.
3. All items "greyed" out caused when the unit does not sense a source input, ie computer or tv tuner. After connecting to a source, you should be able to go and adjust contrast and/or brightness settings
SOURCE: proxima ultralight projector won't project when I hook it up to my PC
Just get your PC settings right and Bob's your uncle
SOURCE: Firmware flash Proxima X350
Make sure the projector is in flash more before connecting. (read flash instructions)
When it prompts for drivers show the uncompressed flasher program catalogue. It should find the drivers for 'Infocus Projector Flash'.
After this you can run the program and continue normal flashing procedure.
Good luck.
