Question about Kenmore Refrigerators
564.9901740 compressor kicks on and off
Fan will come on but compressor wont kick in on wall unit ac
The start capacitor on the compressor is bad. Replace it and the compressor will run.
Jun 30, 2013 | Heating & Cooling
Refrigerator model bx21vl does not cool. I can hear the compressor kick in but it kicks out in 5-10 seconds. Then after about 102 to one minute it kicks in and out again,
Compressor is tripping on overload. You may just need the overload and relay replaced due to a bad compressor relay. The relay is what switches the compressor from it's start winding to it's run winding. If you pull the relay off, shake it to see if you hear lots of rattling inside, that's a sure sign of a bad relay. I would replace both of them.
Here is the overload relay to order.
Here is the start relay to order.
Nov 27, 2012 | Refrigerators
I have a Magic Chef Refridge MCBR 1010W that has stopped cooling, fan runs and you can hear it kick in but then kicks off? An Ideas?
If the compressor kicks in that tells you the compressor relay and board are probably good. HOWEVER, when you say it kicks off right away that is not a good indication! It sounds like a compressor problem. Is the compressor extremely hot or is the condenser coils icing up? If so, I wouldn't invest the money into repairing it, because it would cost more to repair than to replace.
Jun 16, 2011 | Magic Chef MCBR440 Compact Refrigerator
Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Jul 29, 2010 | Haier Freezers
Kenmore Coldspot compressor kicking on and off
It sounds like you may have toasted one of the starting componets. Either the start relay or the start capacitor has probably failed, causing the compressor to try to start, and then kick off on overload. Hope this helps
Sep 10, 2009 | Kenmore 50522 / 50524 Side by Side...
Compressor not kicking in when i turn the air conditioning on.
what is the make and model? how long has it been switched on? is the compressor top hot?
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
Compressors Won't kick on
could be tripped on high pressure id clean both . Tom
Jun 17, 2009 | Heating & Cooling
Window Air conditioner pulls too many amps
Probably Seems Replace Running Capacitor Located in Component Box or Nearby Compressor
Jun 23, 2008 | Whirlpool ACQ108XL Air Conditioner
Refrigerators Logo
22 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
