The washing machine won't drain the water? NEC NW-652 6.5kg
2 Suggested Answers
SOURCE: washing machine nec nw-652
i am having the almost the same problem with what i have, if it is turn, the water will just keeping on pouring in non stop, it does matter wether it is wash, rinse, dry or spin the water will just keep on pouring in at all time, it is not a good machine at all.
Posted on Oct 15, 2008
My NEC NW-81R top loader when it turns on does not make the usual introductory series of beeps and is stuck at a spin cycle but won't start. The only button that works is the power button...any...
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 24, 2011 | Washing Machines
I am having a problem with my NEC NW752 Washing Machine. It runs through the cycle but will not drain the water. There were no kinks in the hose and when we hooked another washing machine it worked fine....
chances are that your daiwood / nec unit has a bad drain pump or perhaps the unit is not level or the drain hose is to high for the pump to pump out the water lastly
if you remove the front of the unit where the pump is located as you will see in the link I sent you there is a trap that may need to be cleaned out it has a hand screw cap that you can open and clean try that first before replacing the pump i sent you in the link NEC WASHING MACHINE WATER DRAIN PUMP NW752 NW891 NW652 NW 891 NW 81R eBay
Mar 04, 2018 | Washing Machines
I am Looking for the meaning to eror code LE on my washing machine it is an nec model No NW 452
According to what's written in the manual...
'LE' will light up if the machine is unbalanced or the lid is open. This can be corrected by following operation: WATER SUPPLYfi RINSEfi DRAIN. However if the unbalanced condition is unchanged despite repeating the above operation, the lamp 'UE' will light up, and the buzzer will sound to indicate a problem.
Jan 13, 2011 | Washing Machines
I have a nec nw-652 top loader when i start the machine the water fills the tub but at the same time i can hear small amount of water is going down the drain then stops. Once the water in machine is topped...
Hi just read your posting.Now can you please let me know where your drain hose is draining to,Is it into the laundry sink or some place else.Can you see the water coming out of the drain hose?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Sep 18, 2010 | Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
The NW - 891 NEC washing machine does not finish the third cycle or drain?
Our nec washing machine nw 891 leaks water into drum when finished , I think it needs new washers, is this hard to do?
Aug 06, 2008 | Washing Machines
Washing machine nec nw-652
Sep 09, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
