Question about HP LaserJet 2420 Printer
10.1003 supply error - HP LaserJet 2420 Printer
Sc 558 error code on Ricoh Pro C720
SC558 is a Oil supply motor error The machine detects a motor rotation error for 5 seconds after the oil
supply motor has rotated for 5 seconds. ?? Oil supply motor defective
?? Oil supply unit defective
1. Replace the oil supply motor.
2. Replace the oil supply unit.
Jan 29, 2015 | Ricoh Office Equipment & Supplies
Supply memory error
Remove cartridge, observe a small chip mounted on cartridge shell..This chip calculates the approximate toner levels, once its reached "Zero" printer says cartridge empty/low replace it.. If the memory is not detected due to any reason printer will say supply error or 10:xx supply error..
Replace this memory if available( locally its available ) or replace the cartridge.. Very few cases same error appears with faulty DC controller..
Ex supply memory:
Oct 28, 2013 | HP LaserJet P2055d Printer
000110-0001
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Jul 15, 2013 | Canon Office Equipment & Supplies
10.1000 memory error
Thank you for contacting FixYa with your printer inquiry.
This error is normally associated with a supplies error. I have extracted information on this error from the HP 6L manual.
Error Codes
Error 10 - Supplies Memory Error 10.XX.YY Exact format is dependent on printer model
    The printer is unable to read the electronic information (elabel) on the print cartridge. This helps track page count and life of consumable.
    XX Description 00 memory error on the cartridge or 01 memory device not found
    10.00.00 Black print cartridge
    10.00.01 Cyan print cartridge
    10.00.02 Magenta print cartridge
    10.00.03 Yellow print cartridge
  1. Supplies used in newer printer models contain a memory chip. The information contained on this chip is dependent on the printer model and the supply. The error 10 indicates a problem with the printer obtaining the information from this chip. The chip may be missing or defective or contain incorrect information. There may be a problem with connection between the memory chip and DC controller. Turn the printer off/on to attempt to clear or reset the message. Remove and reinstall the supply, replace the supply.
  2. Replace the memory chip cable/connector or the DC controller.
    How did we do?
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 08, 2011 | HP : HP6L Laserjet Printer
Hi, i have cp2025 printer and it giving an error 58.04 could you please help thanks
Solution or Workaround:
NOTE: Replace the low voltage power supply before replacing the fuser or fuser power supply.
A firmware upgrade is available on www.hp.com that will solve this issue.
If the error will not clear after the firmware upgrade, replace the low voltage power supply.
If the error continues, replace the fuser power supply.
If the error still continues, replace the fuser.
Cause:
Low voltage power supply malfunction.
I hope this information helps
May 12, 2011 | HP Laserjet Cp2025n Printer
I have a printer HP CP2025, it gives me the follwoing Error 58.04. What I can do ?
Cause:
May 10, 2011 | Office Equipment & Supplies
Error 704 Check Supply
Check to see that you have the correct supply selected under "supply type". Are you running black mark supplies or die cut supplies? If the supply type selected doesn't match your actual supply type, you'll get a 704 error. It's also possible that the black supply sensor could be broken, or your platen roller (large black roller) needs to be cleaned. Clean it with alcohol.
May 14, 2010 | Paxar Monarch 9825 Thermal Label Printer
I get the error 2200 message everytime I try to send a fax
Hello there:
this is a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message2.gif.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.2
Power off the AIO and remove the power supply from the back of theunit. Open the scanner cover. Check the scanner glass for cracks andthe scanner casing for cracks. Close the scanner lid. Open the topcover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.3
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Insert the colorcartridge, close the top cover, reinsert the power supply, and power onthe AIO.
Yes: Repeat step 3 with another color cartridge. If the printer2.gif fails again, continue to step 4.
No: Repeat step 3and install the black/photo cartridge. If both cartridges areinstalled, attempt a test scan. If the error message does not reappear,the error is resolved.4
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Remove the color cartridgeand insert the black/photo cartridge. Then close the top cover,reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark.If the error message does not appear with both cartridges installed,attempt a test scan. If the error message does not reappear, the erroris resolved.
Nov 10, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My 50 in plasma has seven red lights flashing please help
If it is blinking red 7 times, and then repeating that would be error code 7 (8V6 supply). Power supply
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Oct 24, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Error Code 63 on Phillips Plasma - what does it mean?
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Mar 30, 2009 | Philips Televison & Video
HP LaserJet 2420 Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
