Panasonic saakx50 Turns on, speakers turn on then after about 3 seconds turns off again
Johnboy36
  • 77 Answers
SOURCE: On off problem
Sounds like it's faulty. is it under warranty?
Posted on Feb 20, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic microwave shuts off
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Dec 25, 2008
  • 108 Answers
SOURCE: Sony Bravia turns off by itself
Replace the BU Mount pcb. Sometimes they are called the FB pcb.
Posted on Jan 08, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave turns off by itself after being on for 3 seconds
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt and
http://www.microwavedisplay.com/disassembly.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Mar 06, 2009
SOURCE: NO PICTURE, NO SOUND, TV TURNS ON THEN TURNS OFF
Well, Everything said on this site is true. I recently had a breakdown on the same type of TV and through this site and the comments left, I was able to repair my tv for less than $50. (Extra cost for upgrading my soldering iron that wasn't getting hot enough) It was amazing. The feeling when the tv powered up and stayed on. Credit goes to Howard and Chris Palmer for their comments. It is possible. You just have to commit and do it. Its not as hard as you might think. Thanks guys.
Tim
Posted on Jan 24, 2010
My Music System (Home Theatre) turns on(indicator turns on) and turns back off .
Is it turning on then off? Could be ur speaker wires connecting and putting into into protection. A multimeter will let u know. Personally, get a cheap onkyo or marantz amp (they do exist lol) and it’ll make ur speakers sound 100000% better. Trust me or I’ll buy it or you for 50% more than u pay. Proof needed tho lol
Jan 09, 2018 | Panasonic Audio Players & Recorders
All of a sudden stopped working and won't turn back on. been 12hrs. when power is pressed, it turns on for 2 seconds and then standby lights blink again and it turns off
This could be caused by a direct short circuit on the speaker outputs. Try disconnecting all the speaker connections at the back of the receiver and then power back on. You can also try a factory reset by holding the surround mode + clear button for 3 seconds.
Feb 14, 2016 | Marantz SR7005 Receiver
I have problem with CD player.
The drive tries to read the CD but fails, then "resets" to try again. It is likely the complete unit will have to be replaced even though the other functions work.
May 04, 2014 | Panasonic Car Audio & Video
My speakerset goes dead every time I try to listen to some music. It just turns off and I can't get it back on(like it has no eletricity). Then after a while(seconds, sometimes minutes) it turns on again,...
It is more likely a setting --either in Windows itself-- Windows Media Player-- or your soundcard controls.
I've had that set for 2-3 years -- every time it was a software issue.
They are great speakers.
Dec 28, 2010 | Logitech Z-5500 Computer Speakers
My kx tg4321b handset resets eventually during conversations in speaker mode, when it turns on again, there is a message saying "Line in use" for a few seconds and then it's ready to make calls again....
mine does the exact same thing, I also bought this phone for my parents house and this problem also occurs with them, did you find a way to get the speakerphone to work without having it cut off?
Oct 25, 2010 | Panasonic KX-TG5230M FHSS GigaRange...
Panasonic pt-51hx42 model tv--When i push the power button the set turns on for a few seconds then turns off. it will not turn on again unless i unplug it and then plug it back in and then it again turns...
I have advice: DOES THE POWER LIGHT GO OFF AND THEN BLINK?
This set has a self check feature---the blinking power light should indicate what is wrong------a series of 3 blinks with a pause is short protection---common here.
A series of 5 Blinks means a short on the 140 volt line, more serious than 3 blinks but still fixable.
These sets all have a "SOS" SYSTEM---at least three protection circuits that will engage if something wrong and not allow the set to come on.
Let me know if a sequence of blinks---easy to miss if you do not know about it.
If this information helped you rate this solution as very helpful as I do this here for free.
If you have questions or need advice respond to this posting with a comment.
REGARDS, SD TECH
Aug 12, 2010 | Panasonic PT-51HX42 51" Rear Projection...
Power
When i try to turn it on the power button flashes a code. The power button lights up once for a second, then turns off, then flashes quickly nine times and lights up once again for a second before turning off. The screen doesnt turn on at all, nor do the speakers. Any help would be highly appreciated.
Feb 11, 2008 | RCA D61W130 61" Rear Projection Television
Yamaha htr5730 receiver - turns off
You may have speaker wires touching each other or a short circuit in the wire. "Check SP Wires" means to check your speaker wires.
Oct 16, 2007 | Yamaha HTR-5730 Receiver
50 people viewed this question
 Grubhead
Grubhead
