Question about Cycling
Bion cycle computer instructions - Cycling
My 2006 VDP had error code and mechanic found nothing wrong. Reset computer and Ive driven 200+ miles and when I try to get inspected it keeps ginVing "not ready" message for two items.
Not ready means that the engine control computer has not completed what is called a drive cycle self test, to do this drive cycle and clear the system asap you need to follow the instructions at the link. Note that during the drive cycle you may get that fault code and check engine light again if the problem you mentioned is still present. How to Perform Basic Drive Cycle
Nov 04, 2016 | Cars & Trucks
Bryton rider 20
This has to be at the sensors. Adjust them closer until you get a reading. May need spacers to get closer.
Apr 13, 2014 | bryton Rider 20 E GPS Cycle Computer |...
Manual for 14 function Challenge Cycle Computer
I have challenge cycles 14 function waterproof cycle computer
but i lost the instruction how to enter the tyer size
Feb 17, 2013 | Cycling
I need a copy of instructions for a pro digi - 7 bike computer
http://cycle.shimano.co.jp/media/techdocs/content/cycle/PRO/SIManual_DIGI-X5-X8-X10_v1_m56577569830638481.pdf
Nov 20, 2012 | Cycling
I need setup instructions for the Ryder Razor cycling computer
do you have a usb cord, you will need that , and then attach it to the pc
more details and I will provide you with the necessary details
Jul 26, 2012 | Cell Phones
With help of a diagram describe a data processing cycle.
Some would say Input, Processing, Output. The diagram would be an arrow from input to processing, then an arrow from processing to to output. Then an arrow from output to Input in this way of looking at it. You will find more complicated descriptions and diagrams, too.
http://technology.blurtit.com/300718/what-is-data-processing-cycle
The data processing cycle:
It is Sequence of steps performed repeatedly by a computer in the execution of a program. The computer's central processing unit (CPU) continuously works through a loop. It fetches a program instruction from memory. Then the CPU fetches any data it needs. Then it applies the data to the program. It stores the result in memory. Then it fetches another program instruction.
Others include more stages: http://www.enterprisefeatures.com/6-important-stages-in-the-data-processing-cycle/
data collection
data preparation
data input
data processing
data storage
data output
Aug 03, 2011 | Computers & Internet
PRO DIGI-X10 10 Function Cycle Computer Need a copy of the instructions
May 31, 2011 | Cycling
Ringtone
Unclear if you're using the TMobile ring tones or some that you have downloaded (or created). BION, I got longer ring times by using longer ring tone recordings. (I got mine from free sites on the net, most tones created by people from their music collections.) If you are using ring tones that aren't from T-Mobile, switch to a TM ring tone and see if that makes a difference. (If it does, then shop around for some new ring tones - the old ones were causing a problem.)
Another possibility is to check settings/phone/auto answer. Be sure this is set to "never." Also check Call Barring. Try having your blocking of incoming calls "off."
And last: put profile on "vibrate" and call yourself. Do you get more than one second of vibration? If you don't, then it's probably a phone malfunction, but if you do, it's a ring tone problem. Fairly easy to deal with. Good luck!
Jul 24, 2009 | T-Mobile Dash Smartphone
ASUS P5LD2-VM Chassis Intrude
Do you mean the pins for the chassis intrusion on the board are broken off?
if not broken then just jumper them and bypass the switch.
Jan 26, 2008 | ASUS P5LD2-VM Motherboard
Cycling Logo
66 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
