Question about Tornado F91P: Piranha Three Gallon Solution Tank
How to install tornado F91P solution tank? how to attach the tube to buffer?
Steam cleaner doesnt spray water anymore
Hello, this is Ava with Think Crucial.
Check to ensure there is a full tank of Bissell Hard Floor Solutions and water. - Make sure the clean water tank is inserted properly by removing the tank and re-inserting it. Ensure the gasket is attached to the water tank and did not fall into the machine. Reattach this gasket if necessary. - Check the valve on the bottom of the clean water tank. The water should come out of the X-valve when pressed. If the valve is blocked, soak the cap and insert in hot tap water until the blockage clears. Check the handle to ensure it is installed properly. Remove the handle and re-attach, making sure the handle is pushed down all the way. If you need to re-install the handle, remove the solution tank and lift the tab as you lift the handle. Check to ensure the solution tube is inserted properly into the floor nozzle. Clean the spray tips by bending a paper clip and inserting this into the spray tips to clean. If you continue to experience no spray, you may need to call Bissel at 1-800-237-7691 for further assistance.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 14, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
How do I hook up the upholstery attachment on a Hoover Spin Scrub 50?
To connect the upholstery tool, first remove the clean water tank by pressing down on the handle and pulling the tank forward. Remove the hose from the storage rack. Press down on the handle release lever and lower the handle to the ground. Unlatch the back part of dirty water tank and remove the lid. Pull the dirty water tank's front panel up about an inch and rotate the panel to parallel with the floor. Replace the panel with the converter and slide it halfway down until it is firmly in place. Pull the collar on the connecting tube towards the tube so that the black tabs are fully extended. Open the door on the hood labeled Stair/Upholstery cleaning connection and press the round solution tube onto the round projection. Press the collar firmly to ensure that the tube is connected. Replace the tank in a hinge-like manner and place the lid under the tabs on the front of the tank. Rotate the lid down onto the tank.
Now slide the upholstery tool on the connector of the hose until the tab locks into place.
The manual for the Spin Scrub 50 is available on the Hoover product page: http://hoover.com/products/details/fh50044/steamvac-spin-scrub-50-carpet-washer-with-tools/ . The direct link to the manual is http://hoover.com/file/1195/ . The directions are on page 14-15.
I hope this helps.
Oct 19, 2015 | Hoover Vacuums
The shampoo is dispensing too much shampoo, it is empty in no time
Hello There,
Is your machine use the water from the tank at all? If your machine use too much shampoo, my guess is it use less or no water at all. In this case the pump is sucking very little or nothing from the water tank and it does from the shampoo tank.
Please look the attached plumbing diagram. After you opened the unit up, you can follow the tubes and clean the system (solenoid valves but mostly the tubes those involved in the water tank circuit)
Good Luck with the repair!
Sorry, I wasn't able upload!
Sep 10, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Why will my hoover spin scrub steam vac upholstery attachment not suction?
With this model, check all hose connections and recovery tank lid. if you have good suction before you put on the tool it may be the tool that needs service. inspect the tube under the recovery tank for the round gasket and the filter inside the tank.
Aug 26, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Bissell 9200-T ProHeat 2X will not spray I have gone through the priming process it will work for a few seconds and quit. I have had it open and checked a few tubes but not sure what to do next. This...
ARE THE TANKS SEATED PROPERLY AND THE AUTO-LOAD GASKETS
IN PLACE?
Check the bottom of the Water Tank and the Formula Bottle to make
sure each has a red (or black) auto-load gasket attached and facing outwards
and that the ventilation tube is not submerged as it allows air in so the solution
can flow.
May 28, 2011 | Bissell 9200 Upright Vacuum
How do you attach upholstery hose
The upholstery hose attaches to the front of the recovery (lower) tank. There is a square plastic duct which must be removed, or folded forward on recent models; and the end of the hose slides into the front of the tank. Be sure to replace the lid on the dirty water tank correctly. The connector on the soap tube attaches to the valve under the trap door on top of the nozzle.
Jan 22, 2011 | Hoover SteamVac F5914-900 SpinScrub...
How to attached stair cleaning attachment
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover F5835900 Upright Steam Vacuum
I am looking for a nilfisk c120.2 pressure hose replacement i seem to have looked everywhere
need to be more specific,is it click an clean tube with tornado nozzel ,or 15m drain&tube cleaner.
Aug 28, 2008 | Nilfisk Vacuums
How to attach upholstery attachment
You are trying to put the tool on upside down. The half moon should be towards the bottom , just like a big smile, the tool attachment sits up off the bottom, I know I was trying to force it down in the wrong direction too. Hope this makes sense to you.
Sep 06, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Tornado F91P: Piranha Three Gallon Solution Tank Logo
19 people viewed this question
Top Tornado Vacuums Experts
JoeVacs
Are you a Tornado Vacuum Expert? Answer questions, earn points and help others
