Question about PfaFF Sewing Machines
HOW TO MOVE BLADE ON PFAFF CALANDA
The top blade is too far to the left and therefor bangs onto the bottom blade and gets stuck
4 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: serger 794 from pfaff--calanda type 794
There are two holes running vertically inside the needle arm.........the needles are held firm by very small screws or hex allen keys.........they may have worked loose over time, if they have fallen out and been lost, it is a call to your  local Pfaff dealer for advice......be sure to quote model number.
Your User manual may have a diagram to assist.
Have you ever changed the needles since buying this machine ??
Needles ought to be changed every 6 - 8 hrs of sewing, and more often with heavy or abrasive fabric.
Posted on Nov 15, 2008
  • 35 Answers
SOURCE: sewing machine repair
I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. You can learn how to repair different brands of sewing machine as well.
Posted on Sep 08, 2010
SOURCE: Pfaff 362 won't zig zag
yes, it's very possible that the control/knob needs to be replaced
or the cam or gear that works the zigzag
Posted on Jun 05, 2012
I have a Pfaff 230. The lever to move the needle to the left or right is not working? It is stuck in the Left position. Suggestions to release without taking it in as heavy to transport
I have a Pfaff 260 that was totally frozen when I bought it at a thrift store. The old oil had turned to glue and seized the moving parts. I followed the process described below and my Pfaff 260 now has a prominent working place in my sewing room.
Berninamatic 910 is frozen Where can find manuals so that can service it
Oct 14, 2016 | PfaFF Sewing Machines
My bobbin winds unevenly, there is always more thread at the bottom of it than there is at the top. Neither switching to the original pfaff bobbin nor either spool position works.
I always use my finger to guide the thread as the bobbin is winding,the bobbin shouldn't be moving around in the metalcase probably needs tightened.
Aug 29, 2015 | PfaFF Sewing Machines
Jun 03, 2012 | PfaFF Sewing Machines
Calanda overlock 792
what is your question?
Jan 09, 2012 | PfaFF Sewing Machines
How to open the top of the Pfaff 7570 machine to clean
Don't bother going in from the top. Don't take out those two screws you see under the handle...they have nuts on the bottom and will drop off. Instead use a Torex screwdriver (think it is #25) and loosen, do not remove, the screw you see down in the left hand space when you raise handle. Screw head is about 2-3 inches down. Use a flashlight. After loosening screw, pull left cover off to expose lightbulb (easy to change now) and other mechanical stuff...you can use compressed air to blow out lint or a brush. Usually not needing oil, but a very little on some of the moving parts helps.
Dec 21, 2009 | PfaFF Creative 7570
Need to locate a lamp changer for the Pfaff 7570
You my be able to change the light bulb without one. On some versions of the Pfaff 7570, you can remove the left end of the machine to access the bulb socket: remove the top cover that has all the designs pictured on it. Lift the carrying handle. Immediately behind the handle is a hole about 3mm in diameter. Down in that hole, probably too far down to see, there is a phillips head screw. Drop a Phillips head screwdriver into the hole, set it into the screw head and unscrew that screw. This will loosen the left end cap. Pull toward the left to remove this piece and you can access the bulb and socket.
Oct 06, 2009 | PfaFF Creative 7570
Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Apr 24, 2009 | PfaFF Tiptronic 2030
Serger 794 from pfaff--calanda type 794
Nov 15, 2008 | PfaFF Sewing Machines
Sewing machine repair
Feb 07, 2008 | PfaFF Tiptronic 2030
Threading a pfaff creative 7570
Always thread the machine with the presser foot up. This keeps the tension disks open while you are threading. Open the lid on top. Put thread on spool holder. Go directly to your left and down the path on the farthest left. Go all the way to the bottom and bring the thread up on the path closer to the spool. Hook the thread through the metal piece that moves up and down while sewing. It should be in the highest position when threading. Run the thread down and clip into the small metal holder above the needle. Pull down needle threader, draw thread across front of it from left to right and pull through needle.
Jan 30, 2008 | PfaFF Creative 7570
Sewing Machines Logo
16 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
