Question about Lands Phones
What's wrong with my panasonic kx tga101cs?
My handsets aren't fully charging. I've replaced the batteries in both handsets. They were in storage for a while. Display is fine. All other functions are fine.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 20 Answers
Did you use the recommended type batteries from and which the manufacturer are prescribing?
Posted on May 30, 2014
SOURCE: I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Posted on Aug 11, 2008
cnavarro
  • 2460 Answers
SOURCE: I have a Panasonic cordless
Start by swapping the batteries between units. If the formerly bad handset charges, it's a battery. If not, look for dirty contacts where the unit sets into the base or the batteries fit into the holder.
Carl
Posted on Sep 01, 2008
SOURCE: Panasonic kx-tga101cs incorrect voicemail message
Press and hold "Clear" until it beeps. It will clear the invalid voice mail msg.
Posted on Jul 28, 2009
sarahkp
  • 11 Answers
SOURCE: hard to hear on one of the handsets
we have the same phones, the volume can be adjusted using the key pad but only slightly the hearing overall with this phone is not so great you end up straining half the time to hear the conversation
Posted on Sep 04, 2009
SOURCE: answering function won't kick in
found what i was looking for on the 'net
thanks
Posted on Oct 07, 2009
Phone says no link to base reconnect to mainbase ac addapter
The instructions worked after the additional KX-TGA402N handset was fully charged and I kept pressing the menu/ok button of the additional handset to advance from initial settings to the handset registration mode.
How do register an optional accessory handset to my existing main base...
Feb 08, 2013 | Panasonic KX-TGA402N 3 Pack KX TGA402N 3...
Require operating instructions for KX-TGA101CS(ic216A-KXTG1031) Thanks
Here you go
http://phone.manualsonline.com/ex/product/headline/m/panasonic/d/cordless_telephone/p/KX-TGA101CS
Mar 03, 2011 | Panasonic KX-TGA101S Cordless Handset
Battery very hot never fully charges [1] next
Try replacing the batteries (think they are 2 AAA's in there)
Feb 28, 2011 | Panasonic KX-TGA101S Cordless Handset
Model number KX-TGA101CS not holding a charge. does not pass one bar.
The rechargeable battery, model HHRP107 probably needs replacing. They don't last forever. The link is for information only, you can buy from other sources easily if you wish to do so.
Please take a moment to rate my reply.
Sep 20, 2010 | Panasonic KX-TGA101S Cordless Handset
My panasonic kx-tga520m cordless handset does not display caller id anymore. the second handset does display this feature. What should I do?
Because your phone was low on battery, you will not see this feature. Once you charge your phone fully, you will start receive phone calls and you will see this feature activating again.
Jan 18, 2010 | Panasonic KX-TGA520M Cordless Expansion...
Hard to hear on one of the handsets
Sep 04, 2009 | Panasonic KX-TGA101S Cordless Handset
Jul 16, 2009 | Panasonic KX-TGA101S Cordless Handset
I have a Panasonic cordless phone, 2 handset model #KX-TGA101CS. Phone # 2 doesn't want to charge. It's been on the charger overnight and I can't get it past 2 bars. They are only about 2 years old. They...
Carl
Sep 01, 2008 | Panasonic Lands Phones
Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Mar 23, 2008 | Panasonic KX-TG6051M Cordless Phone
Lands Phones Logo
78 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
