U can remove front panel by taking a putty knife and push back clips located in between the top panel and front panel. the front panel will fall towards you at the top. lift panel up to remove it off of the hinges at bottom. u should be able to expose the tub and everything else inside the cabinet of washer. put washer on small load and start the cycle. should not take long to find out where the water is coming from.
Get a putty knife and remove the front panel. with your putty knife you need to find the clips between the lid and the front pand and push the clip in and pull the front panel towards you. the clips are located to the very left and right. about 1-2 inches in. you will be able to see where the leak is comeing from. let me know how it goes or if you need more help
¡æThe drain pump filter
• The drain filter collects threads and small objects left in the laundry. and rubber from rugs
Check regularly th
1. Open the lower cover cap
with a tool such as coin.
Turn the drain plug to pull
out the hose.
at the filter
Unplug the drain plug ,
allowing the water to flow out.
At this time use a vessel to
prevent water from flowing
onto the floor. When water does
not flow any more, turn the
pump filter open to the left
is clean to ensure smooth running of your machine.
Remove any foreign objects from
the pump filter . After
cleaning, turn the pump filter
clockwise and insert the drain
plug to the original place.
Close the lower cover cap
Thank you very much. I will try this and see if I can find the leak and determine whether or not to fix it or buy a new one.
