Question about 5900 SST 2-Way Security System / Remote Start System with Responder S
Viper 5301 alarm not locking gas door 2001 BMW M roadster?
I purchased a Viper 5301 alarm and had it installed by the installer. They can not figure out what to tap onto th lock the locking gas filler door, they said it is not on the wiring schematics. It locks with the car doors when locked by turning the key from the outside of the driver & passenger door and worked with the replaced BMW factory add on alarm that was replaced. If locked with the key, the viper will unlock the gas door when disarmed. It seems to only not get the lock pulse signal? If anyone knows what wire to use I would be grateful. The car is a 2001 BMW M Roadster.
Thanks, Steve
  • devignester Jun 22, 2009
    The alarm is installed and working fine except for the locking of the gasoline filler door and is not in valet mode.
  • devignester Jun 23, 2009
    I only need to know how to get a lock - pulse signal to the gas filler door on a 2001 BMW Z3 M roadster.
  • 15,935 Answers
It requires a dual pulse signal to lock and unlocks with the passlock single pulse disarm - doesnt it?
I havent done many of these cars - and its likely no one has much experience with them.
I have exhausted all my resources, and colleagues - and your best bet is going to be at the dealership parts counter.
They will be able to look up the diagram for you to see where the harness is that integrates the gas door lid lock into the vehicle.
I can recall it is a dual lock pulse - but tracing the wires down would have to be an in-car thing that any legit. install bay should be able to handle.
Thanks for using Fixya!!
Posted on Jun 23, 2009
  • 583 Answers
viper has an internal relay that supplies a 10 amp (+ or - depending on how the fuse is placed in the viper) output for the parking lights - the connection chart here shows a connection to the headlamp switch - it looks like that connection drives the coil in the explorer relay
connection chart info:
parking lights (-) - white/purple - driver kick panel
parking lights (+) - white/black - headlight switch
This wire should be connected to the parking light wire in the vehicle.
For parking light circuits that draw 10-amps or more, the internal jumper must be switched to a (-) light flash output. P/N 8617 or a standard automotive SPDT relay must be used on the H1/11 light flash output harness wire.
Light flash (+)/(-) polarity
The internal fuse is used to determine the light flash output. In the (+) position, the onboard relay will output (+) 12V on the white wire, H1/11. In the (-) position, the onboard relay will supply a (-) output. When wiring into a multiplex circuit, you can replace the fuse with a resistor
to get the schematics.click this link directly and register in the site and get the schematics
http://www.drdetailshop.com/deiinstallguides.htm
thanks.keepupdated.
Posted on Jun 22, 2009
  • 3,230 Answers
If you are finished with the install, then it's in valet mode. if you are still working on the alarm it's on because the alarm needs a ground (Green wire).
Good Luck!!
Thanks
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I installed a viper remote start 5101 in my 1997 Chevy z71 it will unlock and lock my truck but will not start or crank my truck but the lights blink when I push the button and it acts like it wants to...
From your description, I am 100% certain that it is WIRED INCORRECTLY. Viper has an excellent customer support toll-free call center, and can help you figure out where the wiring went wrong (it does NOT wire the same as your Avital did.) Best of luck to you!
Jul 20, 2014 | Vehicle Parts & Accessories
I have a Viper 5301. Just recently the blue light on the valet stopped blinking when the car is locked with the remote. It just stays on all of the time, no blink. At the same time, the remote started...
The blue light on solid means that your alarm is in the valet mode. Open any door, press lock, unlock, lock. This should put the alarm back into an active mode. Afterwards, check the system for normal operation.
Apr 14, 2011 | 5301 LE 2 Way Car Remote Starter System
Just notice blue lights flashing in the car. I unlocked, from inside the house, and manually locked from the lock on the inside door. That stopped the flashing blue lights. What has caused...
Do not be alarmed; the blue light is flashing because you used the remote to lock/arm the vehicle. It is a visual theft deterrent, even if you do not have an alarm. It's normal. The reason the light stopped flashing is because you unlock the vehicle with the remote and locked it with the door switch.
Feb 11, 2011 | 5301 LE 2 Way Car Remote Starter System
My viper 5002 alarm i don't know witch wire's to use off the viper alarm's for the power lock's
The door lock wires for the Viper alarm are green (-)lock and blue (-) unlock. The Viper system only provides a negative lock/unlock pulse for the door locks. So, if you are working on a vehicle that has positive door locks you will have to install relays to change the polarity.
Nov 08, 2010 | 5002 2 Way Car Alarm with Keyless Entry...
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
How to activate alarm 2001 bmw 325ix doors lockand unlock with key but alarm doesn't activate, lights don't flash (new car to me) if the indicator light flashes, does it mean that you have the alarm...
The flashing light does not mean you have an alarm. They were not standard in the 3-series.
You can get one installed or if you want the dealer can program the lights to flash when locking and unlocking doors even with out alarm. This is called "acknowledgement without DWA"
May 26, 2009 | 2001 BMW 325
locking and unlocking with the key is to deactivate the alarm not activate it, the alarm is activated every time the car is locked with the remote automatically, u need do nothing else
May 03, 2009 | 2001 BMW 325
Alarm goes off for no reason 20-30 minutes after i lock doors
remove the battery from your remote and see if works
Mar 12, 2009 | 2001 Dodge Viper
Power door locks
You will need two power door lock actuators. They are pretty easy to install and would be wired to the new alarm system.
From what I see, decent DEI ones go for about 50 a pop. Atleast, in my area retail. If its something you are interested in, as of Aug 18th I still have two BRAND NEW in box that I never used on a client's old honda DX. Both the high powered versions.
Hit me up if interested sometime ddowling06 at g mail .com
Jul 08, 2008 | Viper Security and Remote Start System...
5900 SST 2-Way Security System / Remote Start System with Responder S Logo
142 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
