Konica Minolta Di1610 Copier Logo
A
Anonymous Posted on May 06, 2014
Caution maintenance call(m2) develop ineo 163
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jan 09, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1911926
Points
11959
Replace the developer and drum and clear required counters
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3 Related Answers
Anonymous
  • 4 Answers
  • Posted on Mar 13, 2008
SOURCE: develop ineo 161
open then close the front door -> the display show " CHANGE DRUM ? YES/NO " -> press yes on the board
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Jun 19, 2010
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Anonymous
  • Posted on Oct 03, 2012
SOURCE: how will i reset maintenance m2 in my copier ineo 213?
Develop ineo 213
2answers
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
How to reset develop Ineo 164 maintenance call m2
Do not re-set you replace the developer. If you reset the copier will think it has new developer then will set voltages according when in fact the developer is old causing image issues and codes, replace the deveploer and run required procedures CLEAR THE COUNTER FIRST
try this site for parts first
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
How to reset the default density in ineo 163v
how to rest develop ineo 163 v default setting
send me all in one driver link develop 163 v for windows 7
Develop ineo 163 maintenance call 2
this is PM call, some items may have reached to its life.
consult Service Representative.
CAUTION MAINTENANCE CALL (M2) CALL SERVICE
Replace the developer and drum/cleaning blade. Also reset the counters after replacing parts then run F8. resetting the counter with out replacing the above items cause image problems. The copier uses the counters to determine voltages on the drum you tell the copier drum is new and it is still old will cause problems.
Maintenance m2 appears my ineo 213 how can i remove it?
unless the drum and developer are replaced not a good idea to reset the counter. causes codes and image problems
2helpful
M2 error service maintenance
m2 for km 163 or 7216 or equivlent models - it reaches alredy the copy life of the mchine consumbles like drum nd developer, you hve to replce it nd reset the progrms
3helpful
6answers
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
