Question about Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Router installation Hello, I have just bought a lap top and have tried installing the Belkin router using the easy installation wizard, however this hasn't worked. There is an option to use the manual installation but this is rather confusing. Help!
  • 2,961 Answers
Re: router installation
Simply connect your laptop to the router using the supplied lan RJ45 cable and then open up your web browser and type in the address bar, this will take you to the router password page, just press enter as by default there is no password.
The next page will show all the menus on the left, select connection wizard and enter your isp password, username and settings.
Posted on Nov 04, 2007
0 characters
3 Points
I am trying to use my lap top will not connect to the wireless belkin router we just installed
check,if you are able to connect other laptop,to the same wireless router if yes issue must be with the laptop itself check,if the wireless switch is enabled if enabled, uninstall and re-install the wireless driver from the device manager
if issue is with the router,try reseting the router
Apr 23, 2011 | Belkin Basic Wireless Router
Installed belkin router for my lap top - doesnt work
Thanks for using Fixya!
You have the right gizmo there. You just need to set it up correctly. If you are in the US contact belkin @ 1 800 223 5546.
You need to know your ISP type first before trying to contact them. Know if you have a PPPoE (High speed DSL with password) Dynamic IP internet (no user name or password required to connect to the internet, usually used by cable internet providers)
After you find the right information just contact belkin and they will assist you with the proper router usage.
Have a great day.
- HotRatchet
Jul 26, 2009 | Belkin Wireless G Router
My install wizard cd rom no longer works, can i get it online?
There is an easy install wizard download here on Belkin's web site.
Jul 09, 2009 | Belkin (54G F5D7230UK4) Wireless Router
Cant load drivers
yes download the firware from the webstie of the belkin of your router then upload it in the router that's it you know about the router default ip address go for it if you not get it in the box is wittiern default ip address ok
Mar 28, 2009 | Belkin (F5D6230-3) Wireless Router
I have a belkin wireless router but lost the cd to it
I have the CD that comes with this wireless router. I was having the same problem too and once I ran the eazy install wizard it took care of all my problems. I just don't know how to share this installation wizard with all of you through this website, if you could let me know I would be more than glad to send it your way. Email me at
Feb 18, 2009 | Belkin (F5D7230-4) Router (587009)
just type into your browser and it will get you into the settings, just as a cd would but you still have to manually enter your settings with either way of setup.
Sep 06, 2008 | Belkin (F5D7230-4) Router (587009)
Easy Install wizard problem
What you can do to fix this problem is not use the install program at all.
To configure your router, in your web browser's address bar, put the IP address of your router (Another belkin router's default IP was out of the box) and click on go. This should bring you to the routers setup, and the password by default is blank.
May 15, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin Installation CD wont install any software for my wireless router
click on the start button, all programs then go to accessories and then the program compatability wizard see if it will run from there if not try start, run then click browse then on the right hand side my computer, then click on the cd drive then the setup one of these should work
Dec 10, 2007 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
We bought a wireless router can you help me set it up where do the wires go
Hello, The wire from your cable modem plugs into the WAN (labelled "connect to modem") port on your wireless router. You then need to install the software on your PC to set up the router.
Sep 30, 2007 | Belkin (F5D9230-4) Wireless Router...
Belkin F5D7230-4 Kit (F5D7230V4SNPDQ) Logo
67 people viewed this question
Top Belkin Routers Experts
 C. Dante
C. Dante
steve morris
steve morris
Are you a Belkin Router Expert? Answer questions, earn points and help others
