Question about Maytag Neptune MAH5500B Front Load Washer
Mah21pndww door release - Maytag Neptune MAH5500B Front Load Washer
Where is fuel door release button on 2002 nissan maxima
The release bar on the left hand side of the driver's seat controls both the gas door and the trunk. Push down on it for the gas door release, pull up on it for the trunk door release.
Jul 24, 2017 | Nissan Cars & Trucks
Fuel door won't open on a 2008 g8 pontiac
Fuel Fill Door Description and Operation
The fuel door latch actuator shares the circuit with the driver door latch assembly. The body control module (BCM), upon receipt of a lock switch lock or unlock signal, will switch the appropriate door lock actuator, as well as a fuel filler door release actuator control circuits to battery positive voltage. The opposing side of the door lock and fuel filler door release actuators is connected to ground by the I/P fuse block through the other door lock actuator control circuit and the doors, along with the fuel filler door release, will lock or unlock as commanded.
Circuit/System Testing
  1. Ignition OFF, disconnect the harness connector at the fuel door release actuator.
  2. Test for less than 1 ohm between the control circuit terminal 1 and ground.
  3. ?‡'
    If greater than the specified range, test the control circuit for a short to voltage or an open/high resistance.
  4. Test for less than 1 ohm between the control circuit terminal 2 and ground.
  5. ?‡'
  6. Connect a test lamp between the control circuit terminal 1 and control circuit terminal 2.
  7. Ignition ON, command the doors to LOCK and UNLOCK by using the door lock switch. The test lamp should illuminate while commanding the LOCK and UNLOCK states.
  8. ?‡'
    If the test lamp remains OFF during either command, test either control circuit for a short to ground.
  9. If all circuits test normal, test or replace the fuel door release actuator.
Component Testing
  2. Install a 15A fused jumper wire between the control terminal 1 and 12V. Momentarily install a jumper wire between the control terminal 2 and ground. The fuel door release actuator should perform the LOCK/UNLOCK function.
  3. ?‡'
    If the function does not perform as specified, replace the fuel door release actuator.
  4. Reverse the jumper wires. The fuel door release actuator should perform the UNLOCK/LOCK function.
Remove the rear compartment side trim (right) panel. Refer to
Rear Compartment Side Trim Panel Replacement .
Apr 06, 2016 | Pontiac Cars & Trucks
Door release
If you can see a small slot beside the left side of the washing machine door, you can use a strong nail file and push the mechanical release tab within, a few pushes on the door to release the pressure due to the rubber seals on the door as you simultaneously push on the release tab within with your nail file would help . It takes some fiddling until you push the tab correctly. Good Luck.
Feb 02, 2013 | Asko Washing Machines
How to open rear door on 2000 buick lesabre electric door swich won't release
USE A SLIM JIM TO POP THE DOOR RELEASE CATCH FROM THE OUTSIDE, THEN ONCE OPEN, REMOVE THE DOOR CARD & REMOVE & REPLACE THE DOOR SOLENOID
Sep 02, 2012 | 2000 Buick LeSabre
Gas door won't open
FIRST: try using the gas release lever from inside the car with the driver side door closed. My 2006 Jetta gas release lever would only work if the driver door were shut and I pulled the release from the inside car interior. Turns out it was a severed door wire (NOT THE RELEASE CABLE). Thus when the door was open, it stretched the damaged wire and so none of the door controls worked unless the door was closed. ie windows, trunk release, and gas release. It was a $600 repair at the dealership, parts and labor! :(
Oct 22, 2011 | 2006 Volkswagen Jetta
I have a 2007 Hyundai Santa Fe, the fuel door lever does not release the fuel door. What should I look at to fix this?
There is a latch inside the fuel door and it may be the case that the latch is a little bent or tight and when you hit the fuel door release the latch isn't releasing because it is bent.
Bend the latch in towards the door hinge a little bit at a time until it releases normally.
Hope this helps,
Cheers,
Dave
Nov 26, 2010 | Computers & Internet
Hi I have a Hotpoint Ultima WT741 1400 Spin washing machine and I am unable to release the door and belive it is broken. I have rewashed the clothes to check that the door lock was not still on and...
There may be an emergency door release tab inside the pump filter access door.....You probably have a faulty interlock which locks the door during operation and is not releasing...Not a big job for a tech.....Nomess
Apr 09, 2010 | Washing Machines
Door will not open. Button release does not release the door latches.
The plastic lever release is more than likely broken. You can order the part from
http://www.repairclinic.com/Appliance-Parts?s=t-KCMS145JSS0-%3d%3dc226g5
It's about twenty dollars.
May 22, 2009 | KitchenAid KCMS145J Microwave Oven
Fuel tank door release, 2004 Honda Civic
The release cable is sticking or broken. To release the fuel door, open the trunk and pull off the fabric liner on the left side of the trunk. Behind this liner is the fuel door release cable; this cable leads to the fuel door and attaches with a twist-lock connector. It is cylindrical with two tabs. Twist the connector clockwise about 90 degrees and it should pull out, releasing the door.
Just remember, the fuel door will not stay closed until you put the connector back in.
Feb 08, 2009 | 2004 Honda Civic
99 Astro lift door latch left side inoperative
I slammed the door shut one time and the door wood not open at all. I had to take the inside door handle off and found that the cables simply came off of their post (inside the door) on the outside part of the door handle. More than likely only one cable has come off its post on your van. I hope this helps!
Dec 01, 2008 | 1999 Chevrolet Astro
Maytag Neptune MAH5500B Front Load Washer Logo
16 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
