Question about Pool & Spa
How do I install a 600 dual geyser 100 litre?
I have had a Totai gas geyser installed model 1051-119/1-RSA-12-A 12 Litre. The cold water drain valve has started dripping water. How do I stop that? Gas input is a 48 kg bottle.
if i understand you correctly you are reffering to an expansion valve. as the water is heated the water expands. there is an expansion valve to stop excess pressure in the system. if the valve keeps dripping when the unit has finished heating then you might be able to clean the valve seat free of dirt or calcium build up. other wise just replace it. under no circumstances should you put a lid on it.
Jul 02, 2017 | Water Water Heaters
My kwikot geyser trips when I turn it on its 7 year old
If breaker trips check
- elements being to high in ohms resistance (worn out)
- shorted elements
- short to ground
- improper wiring or voltage per nameplate
May 19, 2017 | Water Heaters
I must calculate how many kilowatts per hour a 3kw 200 litre geyser will take to heat the water to 70 degrees celsious
go google and type in ---formula for heating water-- it will shows as so many btu or kilojoules to heat 1 liter of water 1 degree in one minute
May 17, 2017 | Heating & Cooling
How do I drain the Kwikot 600 dual geyser to replace the element
If the design is typical, there should be a drain valve at the bottom. There could be simply a plug that has to be removed for draining.
Jun 27, 2016 | Water Heaters
How do I find out when the geyser was installed
It would be nice to know if you are referring to Geyser software, the utility for screenwriters using Fountain format or rather Traffic Geyser, a marketing tool which drives traffic to websites. You are probably referring to neither!
Look at "date modified" property of the directory that the application was installed in. For example the date of the "Microsoft Office" directory in "C:\program files". It would be unusual if the directory time stamp had changed since installation.
Sep 27, 2014 | Computers & Internet
What kind of oil goes in an 07 gsxr 600
any one off these buddy
SILKOLENE PRO 4 PLUS 5W-40
SILKOLENE PR 4 10W-40
SILKOLENE COMP 4 10W-40
SILKOLENE SUPER 4 10W-40
APPLY 2.5 LITRE ADD AN EXTRA 0.3 LITRE FOR OIL FILTER SO 2.8 LITRE
Sep 18, 2009 | 2007 Suzuki GSX-R 600
Pool & Spa Logo
26 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
